bypass gooseneck
Old Aug 10, 2022 | 02:49 PM
Dave Redline's Avatar
Default bypass gooseneck
hello all,
I am currently chasing down coolant leak(s0 from the valley area. I just assumed the leak was from 22 year old hoses in the valley. I changed them and thought everything would be fine. No, still signifigant leak.
I disassembled and inspected the valley and I think the ls coming from the bypass gooseneck. there is a boss machined and drilled and threaded for a 4 bolt flange for the gooseneck, but I have a 3 bolt flange gooseneck and it is leaking where the 4th bolt would be. Do 2000 XJR"s normally have a 3 bolt gooseneck. Where might I get a 4 bolt gooseneck.
Thanks,
Dave Redline
Old Aug 10, 2022 | 04:20 PM
Sean B's Avatar
So the induction elbow are all 4 bolt. There isn't a direct coolant line in that area.
If your engine has the AJ27 throttle body, they're fitted with a coolant line - that could be leaking as a wild guess.
The header tank can crack and leak coolant down so check that area also.
I cannot recommend the Jaguar site highly enough if you're a hands on owner...
https://parts.jaguarlandroverclassic.../brand/jaguar/
Old Aug 10, 2022 | 07:55 PM
motorcarman's Avatar
SuperCharged engines have a different coolant block connector. (3 bolt connection)
Old Aug 11, 2022 | 07:56 AM
leaddog11's Avatar
thanks
Old Aug 11, 2022 | 01:33 PM
I have found out that the part that I'm looking for is called a coolant spout. Is there a reason that a 4 bolt spout from anXJ8 wouldn't work on my XJR.
thanks,
Dave
Old Aug 11, 2022 | 10:40 PM
M. Stojanovic's Avatar
It will work as it is the same part number (and still 3 holes).
djpxk8
Jan 7, 2022 02:28 PM
Jag1968
May 27, 2021 10:39 AM
jamdmyers
Mar 15, 2015 02:00 PM
jahummer
Feb 24, 2015 10:39 PM
richard thomas
Nov 11, 2012 04:35 PM
