A/C Compressor not rotating
Old Jan 4, 2023 | 02:42 PM
etachu's Avatar
Default A/C Compressor not rotating
I'm not getting cold air. On inspection I found out that the compressor doesn't rotate even though the AC button is on and the fan is blowing hot air.
Could this be a relay or fuse problem. I need advice, please.
Old Jan 4, 2023 | 03:28 PM
RJ237's Avatar
More likely you need a recharge due to a leak. Any quality A/C shop will check.
Old Jan 4, 2023 | 03:45 PM
RandyS's Avatar
Much cheaper to buy a gage and charge yourself if needed. It/s not hard to do.
Old Jan 5, 2023 | 11:07 AM
Jhartz's Avatar
Likely need a charge and/or a replacement switch (just aft of the radiator on the the left side; if you see green goo, it is blown). Ditto, any good A/C shop; which may be rare in Nigeria.
dansxj6
Nov 27, 2014 02:32 PM
supra-raleigh
XJ40 ( XJ81 )
Oct 15, 2014 09:32 PM
mike213735
Sep 6, 2013 04:40 PM
jagspeed
Aug 1, 2011 11:41 PM
equicor
Jun 25, 2011 01:32 PM
