Can I shave-down the valet key into a regular key?
Old Nov 22, 2012 | 12:54 AM
vdpnyc's Avatar
Question Can I shave-down the valet key into a regular key?
It looks like the only difference between the two is the "shoulders" at the end; can I just shave-down the sides of the valet key-end to have the same shoulders and it will work like the regular key?
Is there any difference in the electronic-transponder for the valet key?
Basically, I have no use for valet mode and need an additional key that will let me open the trunk/fuel-door.
Old Nov 22, 2012 | 01:42 AM
plums's Avatar
No difference in the guts. It is only the tip that is different.
Old Nov 22, 2012 | 03:00 AM
steveinfrance's Avatar
There was a thread on this but I can't find it.
Here are the two keys
To mod your valet key carefully file the tip to 4.5 mm (0.175") diameter for a depth of 2 mm (0.08").
Take the same amount off both sides of the key.
My two master keys measure 4.5 and 4.4 mm at the tip so a bit under 4.5 mm is OK
Old Nov 22, 2012 | 12:07 PM
vdpnyc's Avatar
Awesome! Thank you for the prompt detailed response.
Has anyone actually done this and can confirm that it does not ruin the key in some way? (concerned that the key would be non-valet but transponder tells car it is valet or something like that)
Old Nov 22, 2012 | 02:24 PM
Yes, do it. The transponder, as Plums said, is the same on both keys.
It has been done several times and, provided you take your time with the file, it will work.
Old Nov 22, 2012 | 08:39 PM
plums's Avatar
You won't even have to reprogam it as the SLM does not know the difference.
Old Jan 16, 2024 | 07:04 PM
tiger351w's Avatar
thanks for the tip - literally. I had only 2 keys, one black and one green key. I followed your info and shaved down the tip to ~4.5 mm. I used my original black key as a guide. Now I have two master keys! Thanks
tip shaved on valet key to make additional master key
Old Jan 17, 2024 | 01:27 AM
Stu 1986's Avatar
And here’s me lamenting about not having a Valet key and wanting to complete the set 😂
Old Jan 17, 2024 | 08:17 AM
vdpnyc's Avatar
This post is from a decade ago, but confirming that I had a locksmith do it and it worked prefectly. The locksmith didn't even charge me, he said he himself was curious if it'd work - took him maybe 1 minute.
Old Jan 17, 2024 | 09:32 AM
RandyS's Avatar
Nice locksmith...I would keep his number around.
Poet
Feb 7, 2025 02:18 PM
Tipptone
Oct 6, 2015 11:32 AM
Jzar
Sep 27, 2015 02:55 PM
redgear
Sep 26, 2015 07:21 AM
PinnacleWax
Detailing / Car care
Sep 25, 2015 12:46 PM
