Can you check tensioners with a bore scope?
Old Aug 22, 2022 | 10:01 PM
pcolapacker's Avatar
Default Can you check tensioners with a bore scope?
Selling engine from a 2001 XJR. Build date January 01, VIN ends with F32726, so didn't come with third generation tensioners. I have a thin borescope with forward and 90 degree camera. Anyone have success going in through oil fill hole to view instead of pulling valve cover?
Old Aug 23, 2022 | 03:13 AM
Sean B's Avatar
They work. But you’re lucky if you find anything, just chain and sprocket view- with the cam cover removed it gives you the 360 visuals.
It’s a steel liner engine, with tensioner updates it’d be very useful/of value.
Old Aug 23, 2022 | 06:53 AM
Z07Brandon's Avatar
It should work. But honestly, removing a cam cover is too easy.
xk8lattmaster
May 14, 2015 09:11 AM
pezzonovante88
Jan 21, 2014 09:13 AM
Mike Graham
Aug 18, 2012 06:50 PM
macsr
Apr 6, 2011 04:35 PM
Tomlite
Apr 17, 2008 04:40 PM
