cannot fill fuel tank
Old Jan 16, 2023 | 12:29 AM
  #41
xalty's Avatar
Originally Posted by alamp0174
team i need some guidance and or help!! Check engine light is on and can not pass emissions test. Had it in the shop and stated the issue was to do with a leak in the rear canister. Not able to find a new replacement part because it is discounted. To add to the issue went to add fuel today and the fuel will not enter the tank. Did anyone come up with the solution?
no year
no model
no answer
Old Jan 16, 2023 | 05:32 AM
  #42
RandyS's Avatar
Originally Posted by ALamp0174
Team I need some guidance and or help!! Check engine light is on and can not pass emissions test. Had it in the shop and stated the issue was to do with a leak in the rear canister. Not able to find a new replacement part because it is discounted. To add to the issue went to add fuel today and the fuel will not enter the tank. Did anyone come up with the solution?
Hello there. your public profile says you have a 2003 Jaguar XJ8 so may we assume that to be the
car you are inquiring about? If so, there are several solutions mentioned thoughout this thread that
have worked for forum members. Turning the gas nozzle 90 degrees seemed to work for some.
1995XJSGuy
Sep 8, 2020 12:09 PM
Joshua Hake
Nov 30, 2019 07:25 PM
BobbyDing
Oct 27, 2018 08:34 PM
Paulbx62
Dec 3, 2017 08:28 AM
elwood
May 23, 2007 06:20 PM
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
