Cannot Find Throttle Body Coolant Hose Replacement
My father's 1998 XJ8 has developed a slow coolant leak at the 3 way plastic connector under the expansion tank where the hose under the manifold meets the octopus hose behind the engine. There is a small hose that comes up from the plastic connector into the throttle body that has worn out. Does anyone know where to find a direct replacement or the proper diameter of hose stock to buy if I have to cut to length? I have looked through dealer parts catalogs, etc and cannot find a replacement. Thank you!
Thank you but this seems to be one of the two hoses that run under the intake manifold. I need the smaller diameter hose that goes straight up into the throttle body at the rear of the engine where this hose terminates. It looks like 1/2" Goodyear hose cut to length should do the trick, thanks again!
Up to VIN 853935 - NCA3976AD
From VIN 853936 - NNE3976CA
However, the above change point does not apply to SC engines for which the change was much later, with the change AJ26 to AJ27 (I believe).
3 WAY CONNECTOR NNE3944BA fits:
Jaguar: XJ8 1998-03 | XJR 1998-03 | XK8 1997-06 | XKR 2000-06.JAGUAR OEM XK XJ HEATER HOSE
2 available on Ebay - Ebayer - jaguarpartsplace (4275 ) $7.39 free shipping
here is the weblink:
https://www.ebay.com/itm/161588957479
achysklic
29
Feb 25, 2025 08:36 PM
SharpJag3
Nov 17, 2015 04:27 PM
SharpJag3
Nov 15, 2015 04:59 PM
Sean W
Jan 3, 2014 04:47 PM
