Cannot Find Throttle Body Coolant Hose Replacement
Old Jan 26, 2019 | 01:08 PM
anduha's Avatar
Default Cannot Find Throttle Body Coolant Hose Replacement
My father's 1998 XJ8 has developed a slow coolant leak at the 3 way plastic connector under the expansion tank where the hose under the manifold meets the octopus hose behind the engine. There is a small hose that comes up from the plastic connector into the throttle body that has worn out. Does anyone know where to find a direct replacement or the proper diameter of hose stock to buy if I have to cut to length? I have looked through dealer parts catalogs, etc and cannot find a replacement. Thank you!
Old Jan 26, 2019 | 07:57 PM
Ltd's Avatar
Ltd
Old Jan 26, 2019 | 07:59 PM
Ltd's Avatar
Ltd
Try the link above. Part number I believe is NNE3946CA.
Ltd
Old Jan 26, 2019 | 08:39 PM
anduha's Avatar
Thank you but this seems to be one of the two hoses that run under the intake manifold. I need the smaller diameter hose that goes straight up into the throttle body at the rear of the engine where this hose terminates. It looks like 1/2" Goodyear hose cut to length should do the trick, thanks again!
Old Jan 26, 2019 | 08:45 PM
M. Stojanovic's Avatar
There are two different shapes of this hose so you have to first look at your VIN. The part numbers are:
Up to VIN 853935 - NCA3976AD
From VIN 853936 - NNE3976CA
However, the above change point does not apply to SC engines for which the change was much later, with the change AJ26 to AJ27 (I believe).
Old Jan 26, 2019 | 09:09 PM
Ltd's Avatar
Ltd
Plus 1 on the NCA3976AD, I ordered one from XKs unlimited in November. Great fit.
Old Jan 27, 2019 | 04:21 AM
jimlombardi's Avatar
3 WAY CONNECTOR NNE3944BA fits:
Jaguar: XJ8 1998-03 | XJR 1998-03 | XK8 1997-06 | XKR 2000-06.JAGUAR OEM XK XJ HEATER HOSE
2 available on Ebay - Ebayer - jaguarpartsplace (4275 ) $7.39 free shipping
here is the weblink:
https://www.ebay.com/itm/161588957479
achysklic
29
Feb 25, 2025 08:36 PM
SharpJag3
Nov 17, 2015 04:27 PM
SharpJag3
Nov 15, 2015 04:59 PM
Sean W
Jan 3, 2014 04:47 PM
TopHatChef
Jul 25, 2010 08:34 PM
