Can't get into the trunk!
Old Oct 20, 2008 | 08:47 AM
Earl Filter's Avatar
Default Can't get into the trunk!
In a moment of stupidity, I pressed the Valet button on my newly-acquired 2001 XJR. Well, I can't get out of Valet mode, and my master key doesn't work in the trunklid (I don't think it did before I pressed the button either). So, now what? I've read that if the trunklight is out, the Valet mode won't turn off, but I found out AFTER I pressed the button. I have two master keys, and nothing is working. Help!
Old Nov 19, 2008 | 10:02 AM
Default RE: Can't get into the trunk!
Valet mode - trunk button on dash nor on remote will work.
But, I did get it open shortly after, going through a hole made next to where the lower right license plate screw goes. With a 6" screwdriver I can take take the plate off and open the trunk in about a minute now. Thanks though!
Old Nov 19, 2008 | 01:19 PM
salsa1's Avatar
Wonder if you disconnect the battery for a while if that would reset back to normal? since you can get into trunk ...where the battery is at...
Old Nov 19, 2008 | 03:43 PM
Once I got the battery fully charged (it wouldn't take a good charge, and I found a cell with low water), it would come out of valet mode by unlocking the driver's door with the key. After that, I was able to open the trunk with the remote and the button on the dash. Low voltage made it do screwy things.
Sorry, it sounded like I still couldn't use the dash or remote button. I've since gotten it all corrected. Thanks!
magmedia
Aug 15, 2019 08:54 PM
bdboyle
Nov 6, 2015 02:07 PM
emilime75
XJ XJ12 ( X305 )
Oct 19, 2015 09:55 PM
magmedia
Oct 8, 2015 03:28 PM
