Can't get it out of Park
Old Oct 19, 2015 | 08:31 PM
hamilton7550's Avatar
On my 2001 XJ8, the first indication that the shifter would not go out of Park, is the "P" would not be illuminated. I changed the brake switch and still had the same problem until I removed the shift console and checked out the PC board connections. I am not sure how your shifter is wired but might want to change the brake switch???
Old Jul 30, 2021 | 11:29 PM
Maverick115's Avatar
Originally Posted by hamilton7550
OK so here's the story. I inherited this beautiful 2001 XJ8 VDP. However, getting it out of Park is a challenge. Looking thru the forum I have replaced the brake switch and found a bad 25 amp fuse in the trunk fuse box. When I replaced the brake switch, the brake lights remain on. I have tried two different brake switches with the same result...brake lights stay on. I replaced the burned out 25 amp fuse didn't notice any difference. I don't have an owners manual so I can't tell you what the fuse does but when I replaced the fuse, all bad dash indicators went off, the Park light came "P" came on, and the car drove fantastic. I came to park it and then all of the bad indicators came on again and I couldn't get it out of Park again. Codes are P 1638 and P 1000. Battery was replaced in Feb and the voltage is 12.68v. Also I've included a picture of the battery and a white wire that is unplugged. Anyone know what this is for? Transmission shift fine...engine runs fine...
left hand side drivers side fuse panel - check fuse # 7 its a 15 amp fuse - my 2000 was stuck in park and interior lights would not not replaced it - works like a dream if the hear clunk noise by the j-gate then the interlock solenoid is working, thanks to member on the site it was a quick fix on my 2000 VJ8 VDP.
magmedia
Oct 8, 2015 03:28 PM
Ragn0r
Sep 29, 2015 10:38 AM
