CATS suspension replacement
Old Sep 14, 2009 | 09:40 AM
Sean B's Avatar
Water pumps are a weak link in this vintage of engine - replace it and the serpentine belt at the same time and it should be ok. Has it had the timing chain tensioner done? Why not do that at the same time you have the belts off?
Active dampers are green, but it sounds like its too early for cats technology though? I thought that was introduced on MY2001 cars, I'm probably wrong though!
Very twitchy? what does that mean exactly, look around for a lower mileage scrapper for replacement dampers.
________
NX650
Old Sep 14, 2009 | 03:53 PM
AlexD's Avatar
Is there a link for more info on CATS? How similar is this to the Monroe / Volvo system that Volvo used on their R series and the modern P24 platform Volvos? Volvo calls it 4C and it's essencially just a traditional shock with a computer controlled valve arrangement. Is the Jag system air based?
philwarner
Oct 4, 2024 01:37 PM
obwoodie
Sep 3, 2015 07:45 PM
arnoldmilk
Sep 3, 2015 07:42 PM
Harry Dredge
Sep 3, 2015 03:04 AM
