Cell phone antenna help
Old Nov 27, 2013 | 06:24 PM
sean's Avatar
Default Cell phone antenna help
The Cell phone antenna on my 98 xjr got tweeked a bit today at the car wash. It was always pretty loose but now it feels like it's barely clinging to the adhesive tape holding it in place.
I thought about removing it since it's useless to me anyway but I don't want to just jump in to pulling it off and possibly doing more damage until I have a better understanding of the anatomy involved.
It looks like there must be a hole in the rear window where the wire feeds through but is there some kind of washer around the cable to form a watertight seal?
Any ideas on how to plug this hole? Or just leave it and what kind of adhesive is suggestec?
Thanks,
Old Nov 27, 2013 | 08:58 PM
luc's Avatar
luc
Thanks,
no hole through the glass
Old Nov 27, 2013 | 10:58 PM
smtguy's Avatar
Luc is right - there is no hole in the glass. Both pieces inside and out are held on with foam adhesive tape, and you can use a razor blade to remove them.
Old Nov 28, 2013 | 12:55 PM
sean's Avatar
That's a relief, I had heard from others that there was a hole in the rear glass but if there isn't one I'll just go ahead and pull the cell antenna and scrape it off.
Old Nov 28, 2013 | 01:14 PM
bigcat777's Avatar
I used a little WD40 to loosen the tape as I peeled/scraped it off. The car looks better without the antenna off anyway.well that's what I think. I also took all the wiring out as well. Good luck Sean, easy job too.
oldjaglover
Dec 25, 2024 04:33 PM
philwarner
Jan 31, 2016 09:36 AM
Glenn Barickman
Oct 1, 2015 04:09 PM
Wayne Enticott
Sep 29, 2015 08:55 AM
