Chain Guide/Tensioner Replacement Price
Old Jul 14, 2014 | 03:22 PM
max224's Avatar
Default Chain Guide/Tensioner Replacement Price
This question is two-fold:
1. I'm pretty sure that my car has the plastic guides and the problematic tensioner. I went to a local shop to get a price to change them out and it was suggested that I also replace the water pump at the same time. The estimate I was given for this work momentarily stopped my heart ($ 2,800!). Has anyone had this work done recently and can tell me if this is the going price.
2. I used to own a foreign car repair shop and have worked on any number of brands, from VW to Ferrari. Is replacement of the guides and tensioner within the capability of a good mechanic, or does it require a variety of special tools and techniques? I seem to recall that someone had posted a series photos showing the steps involved in that project.
Thanks in advance for your comments and/or suggestions.
Max
Old Jul 14, 2014 | 04:30 PM
Britrover's Avatar
Hi Max - My local dealer gave me a quote of $1200 for both primary and secondary tensioners. I will dig up the link I found where you can buy the whole kit including the water pump for $1100 and you can either do it yourself or find a mechanic that can do it for much less.
Old Jul 14, 2014 | 04:31 PM
Britrover's Avatar
Here is the link - Continental Imports Mail Order
Old Jul 15, 2014 | 06:41 AM
jrb53's Avatar
I got all the parts needed from Christophers foreign car parts .com for $700 for timing chains and tensioners.plus you can rent the tools needed for $100-120 for the job. my mechanic charged $500 to do the job.while you are at it clean and change the oil pan gasket .hope this helps
Old Jul 15, 2014 | 11:09 AM
max224's Avatar
Thanks for all of the helpful replies and the quotes on parts and labor. The parts prices being quoted here are pretty much in the ballpark of what I was expecting and, frankly, the job itself is probably within my capability. However, knowing what I do about Murphy's Law, along with the prospect of working in a hot garage has me looking at farming it out to a good mechanic. But a quote in the $ 2,800 range is a real deal breaker for me.
xjrjag
Nov 27, 2025 09:16 AM
SD96XJ6L
Jan 12, 2022 04:30 AM
Shawn Svacha
Nov 4, 2019 02:47 PM
David Mason
Sep 3, 2015 03:17 AM
Bcrary3
Aug 31, 2015 11:29 AM
