Changing Rod and Main Bearings with engine in car?
Old Apr 26, 2010 | 09:44 PM
Sinister 1's Avatar
Default Changing Rod and Main Bearings with engine in car?
Can it be done?
On american V8's I've been able to get at rod and main bearings by just dropping the oil pan. Trans and everything stays in.
Can the rods and mains be done on these 4.0 XJ8's with the engine and trans in the car?
Thanks, Ken
Old Apr 27, 2010 | 05:21 AM
Sean B's Avatar
No.......
Old Apr 27, 2010 | 09:51 AM
Sinister 1's Avatar
Ugghh....
Old Apr 27, 2010 | 11:33 PM
JWT's Avatar
JWT
Sinister,
What's up with the bottom end?
Old Apr 29, 2010 | 08:29 PM
Sinister 1's Avatar
No real problems...
I have an oil leak that I believe is the rear main. If I go through the trouble to get at it, I figured I'd also do the bearings (using the cotter pin trick) if I could get at them.
The oil leak is not bad. The problem is my driveway only has a couple spots on it and I'd like to keep it that way.
Also have a slight rough idle that goes away when rpm increases. I believe the VVT is not getting enough oil pressure due to clearances on my 135,000 mile engine. This issue might be solved once I change the oil to a thicker viscosity though.
BrentGardner
29
Dec 16, 2024 12:13 AM
rusty37
Jun 7, 2016 04:43 PM
RaceDiagnostics
Dec 11, 2015 10:12 AM
TC Johnson
Aug 29, 2015 08:55 PM
Vector
US Lower Atlantic
Aug 26, 2015 05:36 AM
