Check Engine Light stays on
Old Oct 12, 2010 | 06:22 AM
alexhauber's Avatar
Default Check Engine Light stays on
Ok here is a good one. Replaced all 4 O2 Sensors, which by the way was a Pain in the rear LOL. Had a 1646 Code which means Passenger Side O2. Now the check Engine Light is still on. Whats the trick to reset the Light if you don't have an Code Reader? I can't get my Emissions done with the light on. Thank you for all ya all's help
Old Oct 12, 2010 | 07:47 AM
steve11's Avatar
ud
You need some kind of scan tool to extinguish the CEL. Autozone will read the codes, but not shut off the light as a policy, unless you can sweet talk them. You can buy one now for practically nothing (less than $50) that will delete codes....providing the fault is cured.
You might still have a problem. I haven't any personal experience with aftermarket O2 Sensors, but if you used a generic O2 Sesnsor replacement, some have reported continuing P-Code faults as it appears the operating voltage range of some generics exceeds the ECMs range threshold.
BrentGardner
29
Dec 16, 2024 12:13 AM
Fraser Mitchell
Oct 1, 2015 04:06 AM
big d
Sep 3, 2015 07:37 PM
tony bosco
Sep 1, 2015 02:06 PM
jagmanv8
Aug 28, 2015 12:28 PM
