Check engine yellow warning light
Old Dec 30, 2008 | 04:16 PM
NorCalDiesel's Avatar
Default RE: Check engine yellow warning light
If your SES or Check Engine light is illuminated, then you have DTC (Diagnostic Trouble Code) stored in your ECM or computer. You should get your DTC's pulled using a engine analyzer or code reader. You will then understand why the light is on.
As for your low coolant. Search on this forum using "Engine Coolant Low". You will find a few posts. If I remember correctly it can be resolvedwith a new cap or sensor.
There is always a reason for the check engine light to illuminate
Old Dec 30, 2008 | 07:28 PM
ArmyJag's Avatar
If you want for Check engine light stop by autozone and they will read the codes for free. Make sure you write them down and you can google them to see what they are or post them up
BrentGardner
29
Dec 16, 2024 12:13 AM
X_Type_South_Africa
Dec 9, 2015 05:37 PM
tberry6686
Sep 20, 2015 03:22 PM
ahunt4
Sep 4, 2015 02:59 AM
Oliver9218
Sep 3, 2015 05:33 PM
