Check rear light problem
Old Feb 10, 2015 | 02:45 PM
dcdecs's Avatar
Default Check rear light problem
Every time I touch the brake pedal on XJR I get the check rear lights message and it goes out as soon as I take my foot off the brake, I have tried a different brake pedal switch changed the complete rear light holders and bulbs from a different car.
All the bulbs are fine the electrical plugs are clean is there anything else that may cause this?
Old Feb 10, 2015 | 02:48 PM
jimbov8's Avatar
If you are sure everything you have changed is good then try running a separate ground wire to see if that helps.
Jim
Old Feb 10, 2015 | 03:11 PM
dcdecs's Avatar
I'm confidant the parts I changed are good the car they came off did not have this problem. Do you mean run a new ground from the tail lights?
Old Feb 10, 2015 | 03:22 PM
jimbov8's Avatar
Yes, it is something the early XK8 owners did with the same problem. Worth a try to see if it works.
BrentGardner
29
Dec 16, 2024 12:13 AM
Fraser Mitchell
Oct 1, 2015 04:06 AM
tony bosco
Sep 1, 2015 02:06 PM
tonydbaker
Aug 30, 2015 11:02 PM
gene1
Aug 27, 2015 08:56 PM
