Chrome Trim around Door Openings Removal?
Old Jul 16, 2010 | 09:54 AM
Sinister 1's Avatar
Default Chrome Trim around Door Openings Removal?
I've decided to send the XJ8 for a fresh coat of paint and want to strip the car before it goes out for prep and paint.
I'm referring to the moldings that are on the body that run from the A-pillar to the C pillar and around the Rear Quarter Window. I've had everything else off once before except these moldings. Any Ideas on how they are attached?
The first opinion I got was the guy thought they were bonded in place but he did not know for sure.
Thanks,
Ken
Old Jul 16, 2010 | 01:56 PM
Sean B's Avatar
I use a wood block wrapped in cotton, and tap with a hammer, knocking up and off. Same way to put back on. The B pillar, use a hair dryer to heat it all up, it's 3M double sided pads, and something plastic to pry it off with.
Old Jul 16, 2010 | 08:53 PM
Sinister 1's Avatar
Thanks Sean!
I have a parts car that I'll practice on first.
Ken
Old Jul 16, 2010 | 08:55 PM
Sinister 1's Avatar
Thanks Sean!
Ken
Old Jul 18, 2010 | 04:30 PM
Fraser Mitchell's Avatar
Check there isn't a little self-tapper screw at each end, (there might or might not be), and be very careful pulling them off, or they will distort or buckle and you will never get them back to shape
Old Aug 1, 2010 | 08:47 PM
Sinister 1's Avatar
Today I pulled the chrome pieces from the drip rails. They came off pretty easily. Since I don't trust myself with hammers around things that can be damaged I ended up using a plastic prybar.
There's a notch about 1 foot up from the end (at the A-pillar end) that the bar fits right into. I applied a little torque and pulled at the end with my other hand. It peeled loose from front to back easily.
The real beasts were the Quarter Glass Trim's. Mine were in place with both double sided PSA and the same urethane adhesive used to bond the glass into the body. I had to cut and hack away at each side for at least 2 hours. That's something I never want to do again. I Even made a special tool to do the job but it still was a bear.
99xk8guy
Sep 29, 2025 10:51 PM
Wolfy
May 28, 2024 08:06 AM
XJsc-guy
Nov 23, 2015 01:56 PM
philwarner
Sep 3, 2015 10:14 PM
davidladewig
Sep 3, 2015 06:32 PM
