Clock gone wild
Old Jan 13, 2020 | 08:00 AM
hstovall1's Avatar
Default Clock gone wild
I have posted about this before but remain flummoxed. After working perfectly for years my dash clock in my 2001 XJ8 suddenly started running fast - really fast - gaining 10 minutes or more every hour. I replaced the clock with a used unit and the same thing is still happening. I have been unable to locate a relay that might be defective and simply have no clue as to what might be causing this. I never realized how often I glance at that clock until it stopped keeping correct time!!
Anyone experienced this?
Old Jan 13, 2020 | 09:30 AM
Highhorse's Avatar
Here's the dash schematic, ...did I give this to you before? I'd meter your leads and see what kind of power is coming in.
Old Jan 13, 2020 | 02:43 PM
Higgins's Avatar
Maybe this is a fault in your Xj8. Maybe you are trapped in a disrupted version of the time-space continuum and the time seems to move faster than your Xj8. Maybe you should track down an eventual fault in the electrical system of your car. But I suggest you instead trade your Xj8 in for a Xjr. If you would, you would also have a better chance on keeping the speed needed to be in pace with that rushing clock
hstovall1
Jun 8, 2019 12:11 PM
Kowalski
Dec 26, 2017 06:42 PM
cobac
Aug 31, 2014 12:20 PM
solerydr
Nov 5, 2011 11:28 PM
Swick
Apr 15, 2010 09:17 AM
