Clunking from back
Old Apr 24, 2021 | 10:57 PM
pcolapacker's Avatar
Default Clunking from back
Replaced shocks all around including donuts on back. When purchased, going over a pavement seam on the freeway would cause a loud clunk. I actually pulled over to check because I though a coil spring must have broke. Now 95% better. Still some clunking when going down a rough gravel/dirt road at 10 mph. Can't recreate clunk when parked by pushing down on each rear corner. A worn suspension bushing? Car has 111k miles. Ideas where to look?
Old Apr 25, 2021 | 12:58 AM
xalty's Avatar
shocks torqued correctly?
hub pivot bearings good?
Old Apr 25, 2021 | 11:49 AM
Jhartz's Avatar
grease the zerk fittings on both sides of the differential. Did you replace the front shock mounts? Always a clunker!
Old Apr 25, 2021 | 12:07 PM
Yes. My test for wheel bearings has always been with wheel off ground push and pull wheel for play. No play.
Old Apr 25, 2021 | 12:08 PM
Yes and yes.
anduha
Aug 29, 2018 05:07 PM
Xdevo1973
XJ40 ( XJ81 )
Aug 23, 2017 09:22 PM
jfleming
XJ40 ( XJ81 )
Mar 8, 2016 06:27 PM
XCrossWindsX
Apr 23, 2015 10:29 AM
Knuckles
Aug 19, 2014 09:31 PM
