Cluster not lining back up after bulb swap
Old Sep 29, 2019 | 01:55 PM
p-Rock's Avatar
Default Cluster not lining back up after bulb swap
Swapped with LEDs but the cluster and plastic part isn't lining up. Tried everything I could
anyone run into this?
Old Sep 29, 2019 | 05:26 PM
Highhorse's Avatar
I've always had to have the screws loose and lifted it up and then tighten them down, but it never had to have been much. Are you sure your seated correctly?
Old Sep 29, 2019 | 07:20 PM
p-Rock's Avatar
The two white pegs on the bottom are in their seat. This is really weird
Old Sep 30, 2019 | 04:07 AM
ericjansen's Avatar
+1 on the screws not lined up, need some attention to line them up correctly.
Old Sep 30, 2019 | 05:42 AM
p-Rock's Avatar
If only I could show how much I've tried to tweak this thing in every way. I'll definitely give it another go - I've reseated it probably 8 times now. No matter what way I hold it up or down the bezel just ends up doing the same thing. Even grabbed a graveyard bezel just to make sure I'm not losing my mind. I'm the type to have this luck with simple projects, lol.
Old Sep 30, 2019 | 05:47 AM
ericjansen's Avatar
Are you sure the cluster itself is assembled correctly (no idea what you did to have them out), and that the wood is lined up correctly?
I removed the gauges several times, remember that lining up those bolts is a bit of a pain, but nothing dramatic.
Old Sep 30, 2019 | 07:22 AM
p-Rock's Avatar
I swapped the 4 168s and the 4 T5s. I didnt take the cluster apart to tackle any of the other bulbs.
I can see the misalignment before I put the wood back on and putting the wood on doesn't cover up the void that I'm seeing
cdma
Apr 25, 2018 10:08 PM
Jay48
May 25, 2017 12:53 PM
seawind
Sep 19, 2014 03:52 PM
Nemisis
Jul 3, 2013 08:24 PM
GreenJewel
Feb 6, 2010 08:30 AM
