Codes and Thermostat
Old Sep 18, 2012 | 03:59 AM
RidenXj8's Avatar
Default Codes and Thermostat
I dont remember the code off the top of my head will try and get it asap. but i have a 2000 xj8 i changed out my ignition coils all good on those codes they are all gone and cars running like a champ but i still have a DEALER CODE coming up and its keeping my check engine light on still... Does anyone have any idea how to delete this code??? Also i have never changed out a thermostat but my car if it warms up to long in the cold like ideling in driveway for 20mins it will blow off my coolant hose, if im riding it hard on the expressway with my a/c on for a while same thing it blows of my hose. i changed out coolant caps to theck that, changed out the clamps flushed out my radiator and changed out hoses still does it, the only thing i can think of it being is the thermostat is sticking...Where is the thermostat located i know its usually located right on top by the hose usually i have a motor covering and such on my engine...can anyone tell me where its located exactly and if pretty much just bolt on like anyother???
Old Sep 18, 2012 | 04:53 AM
plums's Avatar
You could check out a few of the "thermostat tower" threads. Some have pictures and descriptions of the one difficult to reach fastener.
Old Sep 18, 2012 | 06:53 AM
jimlombardi's Avatar
Hi RidenXj8
Welcome to the forum.
Here is a weblink to forum thread that has positings with instructions on thermostat tower removal (also has thermostat removal and engine covers removal info) go to post# 19:
https://www.jaguarforums.com/forum/x...heating-58056/
Jim Lombardi
Old Sep 18, 2012 | 07:11 AM
JimmyL's Avatar
What is a dealer code ? Do you mean the check engine light is on ? I had a hose blowing off. It turned out my electric cooling fans were not coming on due to a blown fuse.
Old Sep 20, 2012 | 05:17 AM
RidenXj8's Avatar
it literally comes on the computer when put the obd on the car as a "dealer" or "manufacturer code" im stoping up there tomaro ill have them pull the code again and ill post it tomaro and exactly what it says but they couldnt clear it.
Old Sep 22, 2012 | 02:43 PM
RidenXj8's Avatar
kk i literally just changed out my thermostat for what ever reason it was different then the factory therm. so i had to do slight fabrication to the therm. cover but now i have a restricted performance light out of no where...i pulled the codes and these are the codes that popped can anyone tell me asap what they are p0455,p1000, p0327
philwarner
Oct 4, 2024 01:37 PM
philwarner
25
Jun 26, 2021 05:43 AM
Doug
Feb 27, 2019 01:31 AM
Philurusso
Sep 20, 2015 07:02 AM
twinstacks
Sep 19, 2015 01:09 PM
