Cold start issue
Old Jan 22, 2021 | 06:35 AM
Matty383's Avatar
Default Cold start issue
Hello, new to Jaguar ownership. I have a 1998 XJ8 3.2. When I got the car, it started fine, however this has got gradually worse! Cold start is worst, doesn't seem too bad once warm.
I have cleaned the MAF which improved things for about a week. But it has now gone back to how it was!!!
Can anyone shed light on any similar problems they have had?
I have been told to change the temp sensor, but I don't know where it is situated, if some kind person could point it out to me please.
Old Jan 22, 2021 | 10:30 AM
RJ237's Avatar
Water temp.sensor is in the outlet pipe, that black plastic pipe under the thermostat. Best to buy a new pipe which will come with the sensor installed. All plastic gets brittle. Have you replaced the thermostat housing with a metal one?
Outlet pipe is AJ85885 for the XK8, should be the same for yours.
There is also a air inlet temp. sensor in the MAFS.
Old Jan 22, 2021 | 03:28 PM
Matty383's Avatar
Thanks for the info. Is there a picture or diagram to show me where the temp sensor is please?
Old Jan 22, 2021 | 04:39 PM
Jhartz's Avatar
In the stickies, look in the SNG Barret Parts Catalogue: you will see it in the cross over pipe, just in front of the engine, just behind the radiator and right above the water pump, with a short stumpy hose from the thermostat housing. It will have wires running from it to the MAF sensor
steveyd1
Dec 2, 2021 10:51 AM
kennyjd
Nov 20, 2015 08:51 AM
ratgawd
Dec 27, 2014 12:21 PM
charliepace
Dec 9, 2010 08:10 PM
robin mayor
Dec 17, 2009 07:45 AM
