Coolant flush
Old Jul 28, 2010 | 01:51 PM
stew52's Avatar
Default Coolant flush
I decided to flush my coolant system, did a few fill and flush cycles until only clear clean water came out. I bought the orange coolant from local Jaguar dealer and 5L distilled water - now here's the thing it appears to have turned green once I filled the system up, anybody got any idea if this is normal?
Stewart
Old Jul 28, 2010 | 02:53 PM
QuadManiac's Avatar
I assume the previous coolant was green?
Sounds as if you didn't get all the old coolant out. Did you turn the heater on full while you were flushing?
Old Jul 28, 2010 | 02:58 PM
H20boy's Avatar
not normal...supercharged?
Old Jul 28, 2010 | 02:59 PM
H20boy's Avatar
Just checked your profile since you dont have your car info in your signature...if you didn't drain/flush the intercooler, you've left some green stuff in there.
Old Jul 28, 2010 | 03:21 PM
stew52's Avatar
Thanks for the quick replies. I did three drains and refills over a week period, the last two drains were clear water with no sign of coolant, Will it do any harm if I leave it?
Old Jul 28, 2010 | 08:01 PM
H20boy's Avatar
You didn't mention if you drained the intercooler separately.
Old Jul 29, 2010 | 12:40 AM
stew52's Avatar
No, I don't think I did, looks like I'll have to do it all over again!! All I did was to open the radiator plug and flush through with a hose, heater on full and engine running on tickover for a short while. Could you give me some tips on the best way to do this job?
Stewart
Old May 20, 2019 | 06:55 PM
LAjag's Avatar
As an Update & Addendum....
Land Rover owners forum talks of flushing system with white vinegar (1/2 gallion) as a cleaning agent for cooling system.
Flush system with heater on high several times with plain water...
Followed by adding 1/2 gallion of white vinegar and "topping off" cooling system with water and running the engine for 20-30 minutes, before draining all remaining crud from the cooling system...followed by final 100% water flush ... then refill with coolant concentrate (OAT or Dexcool) and bal;ance until full of distilled water.
Why concentrate? On chance that some air-locked water in the system might dilute a 50/50 premix coolant.
Why vinegar? An exceptional cleaning agent of calcium buildup in aluminum parts, plus easily available and inexpensive.
Question to all experienced Jaguar techs... What are your thoughts of negative effects, if any?
MrWhite
19
Jun 14, 2022 07:49 PM
X308XJR
May 20, 2019 06:50 PM
RaceDiagnostics
Apr 4, 2016 04:00 PM
vwbusbits
Oct 13, 2015 03:43 AM
