Coolant hoses blowing off
Old Oct 23, 2012 | 04:30 AM
RidenXj8's Avatar
Default Coolant hoses blowing off
I have a 2000xj8...i posted a few months back havnt gotten back to it but i did change out my thermostat to start...so the problem...Randomly i will be driving and when i park the car sometimes my hose from the coolant reservoir to the radiator blows off thus leaking coolant everywhere...i thought maybe it was my thermostat sticking...someone mentioned something about the fan inside that creates circulation sometimes going back becuz its plastic...now i did notice that when this happens and i refill the reservoir it doesnt circulate immediately it takes a few minutes sometimes pushing the coolant back out so im guessing its this...2nd problem how do i change the propeller inside??
Old Oct 23, 2012 | 05:07 AM
It still sounds like a sticking Thermostat although the Water Pump (the plastic impeller in this is what you will have read about) could be faulty.
Be very careful with overheating the V8 as it can quickly cause serious damage. The temperature gauge gives no warning until it's too late.
Old Oct 24, 2012 | 05:48 AM
RidenXj8's Avatar
yea im aware of that..but i put in a brand new thermostat so it cant be that...is changing out the pump hard? never done?
Old Oct 24, 2012 | 05:57 AM
RJ237's Avatar
No, not difficult at all. You do not have to remove the fans. I think you will find instructions in the How To section, either on this forum or the XK8 forum, or at Gus's site jagrepair.com.
RJ_______________
95 XJ6 120K mi
97 XK8 86K mi
Old Oct 24, 2012 | 06:13 AM
When you fitted the new Thermostat, did you make sure the 'giggle' pin (arrowed in the drawing below) was at the top:
This allows air to bleed.
When changing the Water Pump, take care not to spill coolant on the Serpentine Belt.
Many of us have regretted not taking the belt off for this job because they start to squeal once they've had coolant on them.
Old Oct 24, 2012 | 06:37 AM
steveinfrance's Avatar
Could it be the filler cap relief valve is stuck closed?
Old Oct 24, 2012 | 09:38 AM
Brutal's Avatar
How are you blowing that plastic pipe off? It has a lock and unless the lock is broken or half the nipple( common, there should be 2 orings on the nipple)
that giggle pin, i snap them off, they make air pockets hard to remove and pressure surges in the system that can work loose hoses like the one that commonly blows off....the lower hose from the housing t stat cover to the radiator. If this is a problem, replace the cover and the lower hose. The barbs on the cover are often smoothed down too much and the hose not as soft as new so it wont grip well.
Old Oct 25, 2012 | 04:35 AM
RidenXj8's Avatar
yes its that hose from therm housing to bottom it has clamp on it but the pressure builds and blows the hose off...the cap is fine i checked and yes i didnt fit the therm like the picture shows i used the same picture wen i put it in...ill try and replace the hoses but i feel like it something to do with the reservoir or somthing inside of it
Wahooesprit
Dec 23, 2019 02:01 PM
Poet
Oct 6, 2015 09:40 PM
Lannyl81
Sep 19, 2015 08:07 PM
OkieTim
Sep 8, 2015 04:48 PM
OkieTim
Sep 2, 2015 12:48 PM
