Coolant system slow leak.
Old May 20, 2009 | 04:08 PM
sparkenzap's Avatar
The cooling tower is the riser that comes up from the manifold to the thermostat housing. It is made of plastic and is a known problem for cracks. An aluminum replacement part is available (try google - "thermostat housing xj8") and costs about $78.00 online. It is a small PITA to change, but I am a rookie (and old and feeble) and I did it in about 1.5 hours. The factory method to change it probably involves removal of the intake manifold, but several of us have done it by buying or making an 8mm wrench and working out the 4 bolts. I would think an independent would do it for south of $225.00 including parts.
BTW, the other plastic ccoling piece, the crossover pipe on mine developed a pinhole, but an aluminum part is not yet available, so I relaced with OEM part. It took 15 minutes, and the part was $65.00 as I remember.
I believe that these partsd are attacked by using non-Jaguar coolant as i did, but I certainly don't know if that is the case. I undersytand that Dex-Cool is a good replacem,entfor Jag stuff and that is what I niow use.
clubairth1
30
Sep 3, 2025 04:38 PM
1100me
Jul 24, 2023 06:10 PM
Wahooesprit
Dec 23, 2019 02:01 PM
jdzubas
Oct 4, 2015 09:14 AM
1100me
Sep 7, 2015 06:26 AM
