Coolent Low warning
Old Sep 23, 2011 | 06:41 PM
switchspencer's Avatar
Default Coolent Low warning
Today wile driving the "Coolent Low" warning came on. So I pulled over to check and it looks as if leaking from the tank by the fire wall. However I can't see exactly where. Can anyone shine the light for me? Where to look & if that's is where I should be looking?
Help Me Please!
Old Sep 23, 2011 | 07:01 PM
test point's Avatar
Welcome to the forum!
The coolant reservoir is famous for having sudden and mysterious leaks.
The best solution is to 'rent' a cooling system pressure test kit from any of several auto parts stores. Pump the system up cold and the leak will be evident.
I had a leak that never as much as dropped a drop or even smelled of coolant. Pumped up the test device and a very fine mist appeared out of the side of the coolant reservoir. But it could be anywhere.
Old Sep 24, 2011 | 11:31 AM
Thank You for the info, I will do as suggested, I will keep you posted as to the results.
Clearly
Spencer
Old Sep 26, 2011 | 10:07 AM
Celeta Moses's Avatar
Default coolent low
I am sure that you know that the engine must be completely cool
in order to check and or add coolent
ericjansen
Dec 19, 2021 12:20 AM
scooternva
19
Oct 27, 2015 02:14 PM
johndahlheimer
Sep 16, 2015 05:44 PM
Johnken
Sep 15, 2015 05:46 PM
giandanielxk8
Sep 6, 2015 07:21 PM
