Cooling fan goes on then off
Old Jun 7, 2011 | 01:27 PM
MoneyMaker's Avatar
Arrow Cooling fan goes on then off
Hello,
I`m having problem with 98m XJ8 3.2l V8
Changed thermostat with metal housing and water pump.
Cooling fan goes on when the temperature line is on the middle and later when the engine comes hotter, cooling fan goes off.
Which parts can cause that ?
Also I changed cooling fan relay.
Give me suggestions what to look.
Old Jun 7, 2011 | 01:51 PM
Sean B's Avatar
genuine Jaguar fan relay? temp sensor bad?
Old Jun 7, 2011 | 01:56 PM
MoneyMaker's Avatar
fan relay is genuine, I haven`t checked the temp sensor, but I will try to change it.
any suggestions?
Old Jun 9, 2011 | 01:49 PM
MoneyMaker's Avatar
the problem is still unresolved......
Old Jun 9, 2011 | 03:20 PM
ronmexico's Avatar
Not sure but I would expect this to be normal behavior... It clicks the fans on when the coolant rises above X temp or always when the A/C is running.
mikiep
Dec 20, 2019 07:37 PM
Seth
Nov 1, 2015 12:17 PM
emilime75
XJ XJ12 ( X305 )
Oct 19, 2015 09:55 PM
LnrB
Oct 13, 2015 12:45 AM
workworkwork
Oct 1, 2015 01:44 AM
