correct lower ball joint..always a project
Old Mar 26, 2021 | 03:36 PM
vincent661983's Avatar
Default correct lower ball joint..always a project
Happy Friday
I posted a thread about the ball joint 2 weeks ago and I ended up getting the lower ball joint from AutoZone. Today my guy Artie/my mechanic was able to tap out the old one with heat torch and hammer.
HERE comes the problem, the new one I got was too small in diameter and the control arm can not hold it tight ... why is just finding the correct ball joint for our X308 becomes a project of endless nightmare???!!!!
I am mentally exhausted. ...
Old Mar 26, 2021 | 04:18 PM
xalty's Avatar
first mistake was buying the part at autozone
https://www.fcpeuro.com/products/jag...kaAmwxEALw_wcB
Old Mar 26, 2021 | 05:41 PM
autozone was never my first option , I was looking at partgeek and they went out of stock and also they have a very interesting shipping system. Their parts are sold in categories and you cannot combine shipping if 2 parts belong to different groups.
I got all of the upper and lower ball joints and control bar bushings from partgeek except the lower ball joint.
Old Mar 27, 2021 | 01:32 PM
nilanium's Avatar
Are your LCA's OEM or aftermarket? I had some MTC (aftermarket) control arms where I tried to replace the ball joint with a URO part, and the bores in the LCA were maybe 0.5mm or more oversized vs the URO's, so they just fell right in.
Old Mar 29, 2021 | 11:45 AM
My mechanic got the lower ball joint from him supplier. I think that's the lemfonder/ZF brand and it is also loose to the original LCA.
i am lost and frustrated. My guy said the since the weight of the car will sit on the lower ball joint. That would be fine?! Really
What am I missing here
Old Mar 29, 2021 | 12:10 PM
my LAC is original to the car. So what and how did you at the end.
Johnken
May 21, 2018 02:40 PM
andrew lowe
Jul 1, 2014 09:44 AM
rocklandjag
May 19, 2014 11:17 PM
hawaiiansurfster
Jan 1, 2013 07:13 AM
Goldlion
Aug 18, 2010 12:37 AM
