Correct Valve Cover gasket set for 99 XJR
Old Jan 14, 2013 | 06:59 PM
Roger77's Avatar
Default Correct Valve Cover gasket set for 99 XJR
Can anyone confirm that this is the correct gasket set?
Fel-Pro VS50610R Valve Cover Gasket Set : Amazon.com : Automotive
Old Jan 14, 2013 | 07:16 PM
Roger77's Avatar
This is the part # provided by Jim Lombardi VS50724R
Old Jan 14, 2013 | 07:24 PM
test point's Avatar
The '99 XJR used the AJ26 engine which has a different cover gasket set from the later AJ27 engines. I would suspect that the gasket set is for the later engine which sells as a FelPro set for around $40. Never seen the earlier set at that price point.
The '99 XJ/K8 used the AJ27 engine and the less expensive parts.
Old Jan 14, 2013 | 08:28 PM
Roger77's Avatar
I thought I had an AJ26 motor and the Lincoln used the AJ27, so does anyone know if FELPRO makes a gasket set for the Valve covers?
Old Jan 14, 2013 | 08:41 PM
Roger77's Avatar
This is confusing, jagservice.net claims
1998 - 1999 XJ8/XJR engines with the last six digits of their
VIN numbers between 812256-F41862 are AJ27 my car was built in Sept 98 as a '99MY
final # of my VIN# is 856522
Old Jan 14, 2013 | 10:59 PM
Roger77's Avatar
based on a few posts related to getting the wrong gaskets, (AJ27) instead of AJ26 I think these are correct
Jaguar V8 4 0L 1997 98 Valve Cover Gasket Kit | eBay
Old Jan 15, 2013 | 06:48 AM
RJ237's Avatar
Roger, FelPro does not make a gasket set for the AJ26 engine.
Old Jan 15, 2013 | 09:35 AM
Roger77's Avatar
I agree, I've been looking all over for a gasket set, but would still like to know what engine I have
Old Jan 15, 2013 | 11:47 AM
Roger77's Avatar
Resolved ***
I have an AJ26 motor, Jaguar could not confirm from VIN#, the Scottsdale service manager said that they can only tell by looking at the color of the gaskets on the car. Orange and grey are AJ26, Black are AJ27
I spoke with my old mechanic and he confirmed AJ26 based on gaskets he used.
So I bought gaskets off ebay for $89.00
http://www.ebay.com/itm/JAGUAR-V8-4-...50230212346%26
Old Jan 16, 2013 | 08:32 PM
Ricop's Avatar
My 1999 XJR had the black gaskets and the Felpro VS50724R set for a Lincoln LS 3.9 worked great.
Old Jan 17, 2013 | 09:49 AM
Roger77's Avatar
Mine is built in Sept 98 as a 99MY, If yours was built later in 99 then you have the AJ27 motor
Sprayall
May 30, 2021 08:13 AM
tberg
Sep 7, 2015 07:32 AM
Sprayall
Sep 3, 2015 07:49 PM
Harry Dredge
Sep 3, 2015 03:04 AM
XFR_Gold
Sep 2, 2015 12:24 PM
