Crank no start
Old May 14, 2021 | 12:19 PM
chriselley's Avatar
RJ.......you might remember when I did the " 1/4 tsp.oil trick in the cylinders of my Nikasil block. a few years ago an you were very helpful at the time. Well I am doing it again after some years,, and I cant remember if you turn it over with plugs in or out, after you put the oil in the cylinders. Can you help with my dumb question
Old May 14, 2021 | 06:33 PM
pcolapacker's Avatar
Give it a tiny squirt of starter fluid. If it fires you know you have spark and it's a fuel issue.
Old May 14, 2021 | 07:02 PM
ericjansen's Avatar
Squirt the oil in the cylinders, put a rag on top, crank it some seconds, put the plugs back in, then start it without touching the accelerator pedal.
One bank only might work though ... saves you time / effort.
