crank position sensor
Old Dec 1, 2008 | 03:16 PM
Idrivejags's Avatar
Default crank position sensor
1999 XJR 98k miles. after researching my issue I would like to replace my crankshaft position sensor. Two questions: 1) Where is it? 2) could I install myself?
Old Dec 1, 2008 | 06:58 PM
Thermo's Avatar
Veteran: Navy
Default RE: crank position sensor
Idrive, the crankshaft position sensor is on the front of the engine, on the bottom near the flywheel. It will be the only sensor in the area that points at the crankshaft. Pulling the sensor is simply removing a screw or two and the sensor will be able to be pulled out. The sensor is a magnetic pickup. So, there is no connection between the sensor and the 35 tooth gear (actually a 36 -1 tooth gear). So, unless you force the sensor too far into the engine (results in damage to the sensor), as long as it is installed, all will be good. You will probably need to access this sensor from under the car, looking up.
Old Dec 1, 2008 | 07:12 PM
Idrivejags's Avatar
thanks for the info- hopefully that will fix my problem.
Old Dec 1, 2008 | 07:26 PM
Brutal's Avatar
ORIGINAL: Thermo
Is that your final answer????
the crank sensor on a v8 is dead center bottom of engine, and at the back of the oil pan, 2 pin black connector. and do you have a code for it? cause its very unusual for 1 to go bad nowadays
mrplow58
Jan 21, 2024 05:53 AM
RoyLittle0
May 25, 2023 02:38 AM
joesoap
Sep 10, 2015 01:09 AM
1964Daimler
Sep 9, 2015 11:28 AM
Doovoe
XJ40 ( XJ81 )
Sep 6, 2015 10:54 AM
