Crankshaft Position Sensor
Hey I’m new to the forum and I’m looking for some assistance. I’m currently experiencing a no crank issue and I was told to check the Crankshaft Position Sensor, but I can’t seem to locate it. Can anyone lead me in the right direction or possibly show me a diagram of its actual location. Any help is appreciated.
A bit of a pain to get at if you don't have a lift, but with the front of the car on jack stands you can wiggle underneath on your back and locate it at the bottom of the bell housing as stated by forum member RJ237.
Just to make things a little more difficult there is some 1/4" piping running across right in the way, but the single screw holding the crank positioning sensor can be accessed with a little determination. If I remember correctly the screw is a torx head.
Congratulations or apologies (depending on how you look at it
If the engine won’t turn over via a starter, it won’t be because of a bad crank sensor. We need quite a bit more info though if we’re to help you get the car purring again. Give us all the information you can that led up to the no crank. There are a slew of no crank posts on here and a seemingly endless list of why the engine won’t turn over. There’s also a big difference between no crank and no start.
)If the engine won’t turn over via a starter, it won’t be because of a bad crank sensor. We need quite a bit more info though if we’re to help you get the car purring again. Give us all the information you can that led up to the no crank. There are a slew of no crank posts on here and a seemingly endless list of why the engine won’t turn over. There’s also a big difference between no crank and no start.
I had a no crank situation: pressing the Start button did not do anything, not even any sound from the starter motor.
At close inspection, it proved that the high current fuse (one of the three on the left side of the battery) was blown.
If you have this, you can see some further issues:
- with battery connected, no 12 Volt on the (+) pole below the left tail light (remove the panel).
If this is the case, you first need to make sure to remedy the underlying issue.
My engine could not be cranked manually by the front crankshaft nut: heavy resistance.
I remedied:
- renewing the engine oil, as there was having a heavy petrol smell at opening of the oil cap.
==> Instead of ca. 7 L of oil in the sump, I pumped out ca. 15 L of mixed oil, petrol and water! Clearly the engine was hydraulically locked.
- manually crank the engine without the spark plugs: engine was now free!
- replace all injectors (nr. 7 injector might not close correctly, since nr. 7 spark plug was completely clean and the others had at least some carbon colouring)
- replace all spark plugs and coil packs (not really needed, but to service the car).
- final step: replace the high-amp fuse
Lo and behold: the engine started running with huge amounts of white smoke: water vaporising from the carter and the exhaust.
Funny thing: before replacing the high-amp fuse, I actually managed to crank the engine by connecting a spare battery to the (+) pole below the left tail light..
Then, I noted that the battery was not charging.
To take out all doubts, I also replaced the (-) battery cable, carrying the Battery Monitoring System (BMS), but to no avail.
It turned out that the generator cable at the starter motor was loose. Also the generator was malfunctioning.
This was serviced at my garage, as I do not have a bridge to do this myself to replace the generator.
The battery is now also properly charging.
So I came quite some way from a non-functioning engine to a runner!
I remedied:
relaxed00
Mar 10, 2012 04:53 PM
CharcoalJag
Mar 31, 2011 07:22 PM
