Damn oil leak
Old Aug 13, 2018 | 03:17 PM
Kejar7's Avatar
Default Damn oil leak
I have this nasty oil leak on my 2003 Vanden Plas with the na 4.0.
it is located on the right front of the engine.
I am not sure what this componet is but could it be the culprit. It seems to leak after it has stopped running and been parked for awhile.
Old Aug 13, 2018 | 05:45 PM
motorcarman's Avatar
I've never seen an oil cooler bypass block installed like that. I guess the engine block started out as a SC and then instead of cooler lines, it was fitted with a bypass block. Maybe a few left over SuperCharged engine cylinder block upper oil pan assys were used with the oil cooler bypass?? Use up the old parts??
Remove the center bolt and replace the 'O'rings!!!!!!!
bob
Old Aug 19, 2018 | 12:08 AM
Kejar7's Avatar
Thanks for the timely reply Bob. I removed the cover and replaced the 4 O-rings. That's the driest the floor has been since I bought the car 1.5 years ago (and not to mention the cheapest at $2.75). LOL
brgjag
Jan 12, 2015 07:14 PM
Jsedita74
May 30, 2011 08:20 AM
rosemont83
Feb 15, 2009 01:58 AM
ArdenX
Feb 7, 2008 12:53 PM
sempaipaul
Jan 9, 2008 08:44 AM
