Darn Valve Cover Leak
Old Dec 31, 2011 | 09:58 AM
inactualis's Avatar
Default Darn Valve Cover Leak
Yesterday I wrapped up a massive set of repairs to my 2000 XJR. I planned to make a celebratory post with pics of the job, but first I need to sort out a stinking valve cover leak.
There's a small but steady pool dripping from the bottom left, passenger side cover bolt onto the (shiny new) manifold gasket, where it eventually drips onto the exhaust. Of course I used all new, OEM gaskets during the repair, and I'm 100% certain I did not over torque any bolts. I am about to:
  • Pull the cover
  • Remove and clean the gasket
  • Clean the groove in the cover
  • Clean mating surfaces
  • Inspect the cover (again) for cracks
  • Inspect the cylinder head for grooves
The cylinder head was resurfaced on both sides during the rebuild, so I don't expect any problems there. Any other ideas before I reset the valve cover? I put a few miles on her last night and after weeks of work it was a pretty magical ride. Can't wait to say this job is done!
Old Dec 31, 2011 | 10:08 AM
Brutal's Avatar
if youre talking about a leak where the front cover meets the head, you should put a small dap of sealant there. There is even a small "pad" there on factory gaskets at this point to apply sealant too. Otherwise you may have "rooled" or displaced a seal when putting the cover on. Dont worry, both are easy fix and occassionally happens to pro's too. Just we know through experiance to watch for this very closly.
Old Dec 31, 2011 | 10:17 AM
inactualis's Avatar
Ah, thanks, Brutal. Should have mentioned I correctly applied the sealant to the two seals. In fact, I got overly **** about what sealant to use and splurged on the $10 stuff from the dealership after grilling one of their mechanics
The leak actually seems to be at the back, bottom corner of the head. Pulling it now to see if I can trace the tracks of oil to the real source. Making me crazy that this one little thing out of a cylinder head rebuild is keeping me from opening up the throttle to check out the new SC pulley I installed!
Old Dec 31, 2011 | 11:48 AM
Brutal's Avatar
the back area you mentioned is the most common spot to roll the gasket. If you take it off now you just need to reinstall correctly. If you wait youll need a new gasket
Old Dec 31, 2011 | 05:08 PM
inactualis's Avatar
Tried to reinstall the seal and it was even worse. Putting it back together now with a seal straight from the dealership. It definitely sits in the cover better than the one from the kit i used for the head gaskets, so it seems the passenger side was just wrong in that kit.
dsnyder586
Dec 29, 2024 07:39 PM
aholbro1
Dec 29, 2024 06:46 PM
bamforp
Aug 14, 2024 05:36 PM
02jagstype
23
Oct 23, 2022 07:03 PM
jaggermang
Sep 8, 2015 07:07 PM
