Dash & clock light out
Old May 4, 2009 | 01:15 PM
SuperSport's Avatar
Originally Posted by tkn77
The STRANGE part is that the dash lights still come ON when I turn the switch one click up from Off. But it goes off when I switch the head lights on anything beyond one click up from off. Any ideas?
It's just a thought, but I think it works this way... On my XJR, there is a brightness adjuster on the left of the steering column. You might have inadvertently turned it down during installation. That, I believe, will cause your lights to go dark when the switch is turned to "On".
I could be wrong, as I did not get any sleep last night.
Old May 6, 2009 | 10:47 AM
SuperSport's Avatar
Ok, I just went out to my car to verify what I was thinking.
If the dimmer knob is turned all the way down, you will have dash lights on with headlight switch off. Once you turn your headlight switch to any other position, your dash lights will go out.
Since that's how it works in my car, I would suggest you check if the dimmer fuse is good, then verify that your dimmer switch is operating correctly. If it's ok, then trace the wiring from there. I've included the fuse location for easy diagnostics. See attached images. To get to the fuse, pull the carpeted heelboard away from the left back seat, and towards the front seat. You will find fuses there (Fuses are found under both side heelboards for future reference, notice second image).
Like I say, I get the exact results you describe when the dimmer knob is rolled all the way to dim.
Good luck, and I hope this somehow helps.
Attached Thumbnails Dash & clock light out-dimmer-fuse.jpg   Dash & clock light out-dimmer-fuse-location.jpg
Old May 7, 2009 | 01:30 PM
NorCalDiesel's Avatar
As a general rule of thumb you should run the shortest possible ground wire from the FM Modulator to the nearest steel body part or ground source. Also, you should run your power wire (with inline fuse) to the rear heel board fuse box. try the left hand heel board fuse box, fuse No. 17. It's a 10 amp accessory fuse. That would be a good choice and should switch off and on with the ignition key. Another possible source would be fuse No.9. That is the radio/cassette source. This should provide power when the radio is on.
Old May 8, 2009 | 09:16 AM
SuperSport's Avatar
No problem at all. Glad it helped. I don't know if you still have the manuals with your car or not, but the image I sent you came from the Free downloadable manuals directly from the Jaguar Website. They can be found here:
http://www.jaguarusa.com/us/en/owner...manuals/xj.htm
The manuals are only available for 2000-2008, but I have yet to find an issue that the 2000 manual does not cover on my '99 XJR.
The fuse locations are in the "Jaguar_XJ_2000_Vehicle_Care_Handbook". This has been very handy seeing as how there are roughly 10,000 fuses in this car (give or take a few). I've never seen so many fuses in a vehicle...
And thanks to NorCalDiesel, you now know where to "safely" connect. Good luck, and enjoy your Jag.
99xk8guy
May 28, 2024 09:36 PM
JarodL
Mar 7, 2024 01:39 AM
Jpav27
Jul 31, 2022 06:43 AM
mrplow58
Sep 9, 2015 11:27 AM
02jagstype
Sep 4, 2015 08:20 PM
