dash clocks going mental!!
Old Dec 2, 2015 | 12:19 PM
Howie's Avatar
Default dash clocks going mental!!
Hi all.
in my on going attempts to fix this pain in the *** car I have yet more symptoms, I need to know if they are connected to the existing issues or not.
I have an intermittent fault with the dash clocks. All of a sudden the rev counter and the temp needles will drop to zero, an array of error lights appear, then after 3 seconds it all returns to normal, it can happen ever 20 seconds or not for weeks.....my main issue is with gearbox faults, which can be generated by a whole host of units so im wondering where this fault comes into play
Any insight would be most welcome....
Old Dec 2, 2015 | 12:24 PM
plums's Avatar
When there are multiple instrument panel faults, the first suspect is
the common ground. And especially when it is intermittent.
Old Dec 2, 2015 | 12:46 PM
Howie's Avatar
thanks plumbs, could you go a little deeper with where to find the common ground please, ive checked ever obvious groung leads i can find on the car, and quite a few that ive found hidden away too.....
Old Dec 2, 2015 | 02:28 PM
Jhartz's Avatar
Howie, what would be useful is to know what car you have.
Here is the wiring for a 2001 X308.
File Type: pdf
Old Dec 3, 2015 | 11:49 AM
Howie's Avatar
its a 98 XJR
09JagXJ
Sep 9, 2020 12:37 PM
Toybreaker
Dec 8, 2015 02:01 AM
Tradefreak
E type ( XK-E )
Dec 4, 2015 11:56 AM
OzXFR
Nov 29, 2015 10:57 PM
Bazz Lambert
Nov 27, 2015 04:14 PM
