Dash light go off & headlights blowwhen i rev the engine
Old Jul 21, 2019 | 08:21 PM
  #61
M. Stojanovic's Avatar
Originally Posted by Sleazy
...now the original problem seems to still be there, the dash lights flicker when the car is running, along with the glove box light, more frustration
I had the same symptom after I replaced my old failed alternator. At the same time, my positive battery cable was getting rather hot near its connection to the battery post. I replaced the cable and also removed and cleaned all contacts at the Mega fuses and the flickering was gone. Later, I also replaced the negative battery cable although it seemed fine (was not getting hot).
Old Jul 21, 2019 | 08:23 PM
  #62
Sleazy's Avatar
Originally Posted by 67ECoupe
Well, looks like you need to get your meter and check your alternator's output, voltages at your fuses, etc., as well as your ground connections for resistance.
Hopefully, it will only be a fuse weakened or a damaged ground by the high voltage output.
I checked the voltage at the battery, 13.86 jumped to 14.10 when flooring it, so it appears the regulator is regulating, as before I was getting 15.5+ at idle, i just have to figure out the flickering now and the restricted performance warning that has appeared
Old Jul 21, 2019 | 08:29 PM
  #63
Sleazy's Avatar
Which ones are the Mega fuses? My battery cable appear to be in excellent condition, no corrosion at either end and they dont get hot, but thanks for the tip. I will clean and re-connect the positive
Old Jul 22, 2019 | 06:14 AM
  #64
Three large fuses in a black box in front of the spare wheel. As for the battery cables, they can look nice and shiny but they tend to develop, over time, resistance in the crimps to their terminals. Anyhow, try first with cleaning and tightening properly the Mega fuses.
Old Jul 22, 2019 | 09:54 AM
  #65
Sleazy's Avatar
are you talking about the fuse box next to the battery?
stham
May 18, 2017 09:44 AM
mbalce
Jul 31, 2015 05:35 PM
BlackMac
25
May 24, 2013 05:52 AM
Jayshmie07
Jul 8, 2012 04:24 PM
RCSign
Mar 4, 2012 08:11 PM
