Dead radio after battery change
Old Jul 6, 2010 | 05:43 PM
roswellman's Avatar
I have the same problem? my dads car took to jaguar dealer and they messed around with it for a while gave it back and now radio does not work or power on? check the basics fuses relays etc not sure what they did?
Old Jul 6, 2010 | 09:08 PM
test point's Avatar
The radio systems have the capability of playing dead in case they are stolen and/or power is removed from the radio. Most North American cars have this feature disabled but yours may be enabled. You will need the correct code to turn it back on. A dealer should be able to supply that code based on your VIN and disable that feature if you choose. As an alternative I would write the code on the inside of the hood/bonnet.
Old Jul 7, 2010 | 03:37 AM
Colin G Kennedy's Avatar
The code is requested on the screen and entered via the keypad, so you first have to find why the HU won't power up.
I have noticed that sometimes after the power has been disconnected from these units it is necessary to hold the on button in for a few seconds before they fire up.
Old Jul 18, 2011 | 05:47 PM
Carlos's Avatar
Originally Posted by ;2107
I had the battery changed in my '02 XJ8 and now the radio will not power up.
I understand about entering the codes that I have but I can't even get the screen to light up. Is the thing "blocked" or is there a way to enter the codes that I am not aware of?
Any advice would be much appreciated.
I am new in this forum and had the same problem in the same year/model Jag. How did you finally solved the problem?
Old Jul 19, 2011 | 03:26 AM
Cadillac's Avatar
I am afraid he will not see your reply considering he is a guest
Forcedair1
Sep 8, 2025 01:57 PM
philwarner
Oct 4, 2024 01:37 PM
jehart49
Sep 12, 2015 05:36 PM
al_roethlisberger
Sep 11, 2015 10:04 PM
edtexas
Sep 4, 2015 08:20 PM
