Diff for 2000 XJR
Old Apr 2, 2012 | 08:41 PM
bergxu's Avatar
Default Diff for 2000 XJR
Hey all,
Going to be picking up a 2001 XJR that's in need of a new pumpkin and I was wondering if the unit from a standard XJ8 is the same ratio and fitment. I think it's a 3:06 if I'm not mistaken. Also, how bad a job is it to swap the diff?
Old Apr 2, 2012 | 09:26 PM
motorcarman's Avatar
All the diffs are the same EXCEPT for the MEXICO and 3.2 liter V8.
bob gauff
Old Apr 3, 2012 | 12:13 AM
adam699's Avatar
This thread will fill you in. If you plan on upping the power in the future, we almost have it figured out
https://www.jaguarforums.com/forum/x...-thread-68571/
Old Apr 3, 2012 | 12:23 PM
SuperSport's Avatar
I hired my neighbor to help me change mine out. It took about 4 hours. We are both shade tree mechanics. And I'm talking about a LOT of shade. It was physically difficult, but mechanically, it went smoothly.
Have a rolling hydraulic jack to drop and pull out the pumpkin when disconnected and it helps a lot.
We did it in my driveway. Jacked only the back of the car and set it on 6 jack stands (5000 lbs is a little scary to lay under). Propped up the Diff with the hydraulic jack, unbolted everything, and pulled it out. Swapped all parts, and rolled it back in. Lining it all back up was a little difficult, but not too bad.
Old Apr 3, 2012 | 02:36 PM
SteveM's Avatar
It's actually 'only' 4000 lbs, but I suppose it would squash you about the same.
Old Apr 3, 2012 | 08:28 PM
SuperSport's Avatar
Ahh, like I said, VERY Shade Tree... My door sticker says GVWR 5002 lbs. I assumed that was Gross vehicle weight. Now I'm guessing that's loaded weight?
Yeah, I don't believe the extra 1000 lbs would change the body squashing that much, but I sure don't like being that far off on my numbers.
Old Apr 3, 2012 | 11:24 PM
adam699's Avatar
This thread reminded me again as to how much I cherish my MaxJax lift.
Old Apr 4, 2012 | 05:30 AM
bergxu's Avatar
Thanks guys. I got the car and am not so sure it actually needs a diff. There's no noise when you set off and it sounds more like a scraping sound which comes only occasionally and from the left rear exhaust silencer area. I have a two-post lift so I'll get it up in the air and have a good root around. Almost seems like a muffler is hitting one of the half shafts or something...will report back!
Cheers,
Aaron
Old Apr 4, 2012 | 09:06 AM
SteveM's Avatar
Yes, that's loaded weight. Curb weight is 4075 lbs. Mine actually weighs less then 3900 lbs. with 1/2 tank of gas.
Old Apr 4, 2012 | 10:47 AM
1999XJR's Avatar
Group Buy?
Quick question... who sells LSD's for the X308? Paramount Performance is the only one I've found so far.
-Caleb
Old Apr 4, 2012 | 11:16 AM
1999XJR's Avatar
By the way, here's the Paramount LSD I was referring to: Click here
And here is a thread providing some information about the Paramount LSD: Click Here
Specifically:
RT QUAIFE Engineering Ltd, manufacturers of Automatic Torque Biasing (ATB) Limited Slip Differentials, have given Racing Green Cars Ltd and TL Jaguar Ltd exclusive rights to the QDF 4W ATB LSD for the Jaguar X100 (steel-bodied XK8 and XKR). The above two companies have also agreed to supply this product for sale by Paramount Performance Ltd - provided they apply the same deposit and retail price structure(see below). TL Jaguar Ltd will fit QDF 4Ws for Paramount Performance Ltd.
So it looks like there are 3 companies in the UK that all sell the same Quaife unit.
Any other LSD units?
Anyone in the U.S. that sells these Quaife units?
-Caleb
Old Dec 28, 2012 | 05:43 PM
x308-XJR's Avatar
2000 Jaguar XJR Specifications | Used
Is this correct that the 2000/X308R equipped with LSD?
Old Dec 28, 2012 | 05:46 PM
richard thomas's Avatar
No.
No LSD.
Old Dec 28, 2012 | 05:48 PM
Red October's Avatar
No, none of the X308 Jags had an LSD fitted as standard-even the XJR.
Old Dec 28, 2012 | 05:57 PM
It's an urban myth.....however it doesn't prevent car breakers advertising XJR diffs on ebay for £400....when you can get exactly that same item (i.e. XJ8) for around £100....:-0
Old Dec 29, 2012 | 12:28 AM
Tirefriar's Avatar
Specifically:
-Caleb
You may want to get in touch with Xenophobe. He acquired an OSGiken unit with excellent results.
peterg19
Feb 10, 2023 09:02 PM
Matei Dima
Oct 8, 2015 11:45 AM
AtholC
Sep 9, 2015 09:07 PM
Super Cat
Sep 9, 2015 03:24 PM
stype40
Sep 9, 2015 08:14 AM
