Different Valve Covers?
Old Jan 7, 2019 | 12:50 PM
biggreenjag's Avatar
Default Different Valve Covers?
Hello everyone - my friend just picked up a 1998 XJ8 with 74,000 mi and we are going through the car mechanically getting it ready for a trip from San Francisco to Texas.
I found oil pooled in the spark plug wells, took off the valve covers to inspect the gaskets and found that each valve cover has a different gasket profile. The left cover had a thinner grey gasket and separated spark plug gaskets. The right had a thicker orange gasket and connected spark plug gaskets. I know that these gaskets go by engine build date and from everything ive read online I think someone replaced the left cover at some point hence the different gaskets. I'm wondering if there is someone here with more experience on these cars can take a look at these photos to tell me what's going on here. I also want to make sure I purchase the correct gaskets for the valve covers themselves so if someone could provide the right part numbers that would be very helpful, I believe I have the spark plug/center ones figured out.
This community has been helpful for us in diagnosing and fixing a handful of issues, including the ABS light issue and very soon the plastic timing chain tensioners we just uncovered.
Thanks in advance!
left cover markings
right cover markings
both
Old Jan 10, 2019 | 07:51 AM
Samilcar's Avatar
The different gaskets are correct for the two different covers. You are right in assuming one of the covers was replaced at some point with the later version (thinner gray gasket).
Old Jan 10, 2019 | 09:00 AM
dwgates's Avatar
Samilcar is correct about the orange & grey gaskets for the earlier valve covers. The new sets though come with the connected spark plug seals for both sides. I got mine from SNG Barrett, one of the board sponsors and they fit nicely when I did this job last summer.. Even better they seem to be sealed up, although I don't think they've even got 5k miles on them yet...I ran into lots of cracks in the plastic valve covers most of which seemed inconsequential but I did have to JBWeld a few of the steel compression limiters back into place before everything went back together. Yours may be in better shape. Don't forget to smear a little RTV over the seam between the front chain cover and the heads. No need to do this job twice!
Old Jan 10, 2019 | 10:40 AM
Cool, that’s what my gut feeling was all along just wanted some peace of mind.
thank you!
Old Jan 10, 2019 | 01:23 PM
motorcarman's Avatar
The cam cover with the separate spark plug well seals ('B'bank) is likely from a later 4.0 supercharged engine (AJ27?)
All the AJ26 engines used the 'double' plug well seals with the 'slits' in the cam cover.
bob
Old Jan 10, 2019 | 07:50 PM
Ltd's Avatar
Ltd
bob
That’s odd. My 98 had the seperate gaskets.
ltd
Old Jan 10, 2019 | 07:55 PM
Samilcar's Avatar
So does mine. That's how I discovered the engine had been replaced at some point.
Old Jan 11, 2019 | 09:48 AM
The 'double' connected spark plug boss seals are used To Engine (9810290000).
Replacement engines and people replacing covers/gaskets are some of reasons why there are different gaskets in the engines?
From engine (9810290001) onward should use NCE2578AA and NCE2577AC but there is a superseded part number for each.
If the cam cover has the 'slits' to hold the early 'double' plug boss seals, then that is what should be used!!
bob
OUScooby
Jan 11, 2019 09:45 AM
stremsjg
Detailing / Car care
Aug 23, 2010 07:04 AM
99kyxjr
Mar 13, 2010 12:41 PM
biffta
Feb 12, 2010 12:18 PM
philsk8ts
Feb 8, 2007 11:27 PM
