Differential Oil Change
Old Dec 1, 2009 | 10:34 AM
Rique's Avatar
Default Differential Oil Change
Hello Folks, I have my Xj8 98 up on stands ready to change the diff oil. I located the vent plug on the top right side of the differential. I unscrewed the darn plug and fit in plastic tubing about 2.5 feet. Problem is tubing does not hit the oil? Tubing moves freelly but does not even get wet?
could it be the vent tube is conical and I need a thiner tubing or is ther another hole I need to unplug.
Thanks much for your help
Rique
Old Dec 1, 2009 | 02:46 PM
joey4420's Avatar
Should put the tube into the full hole... if you are doing that an not hitting and oil... you may have an issue i.e. your bone dry and this is bad.
Old Dec 1, 2009 | 09:17 PM
sparkenzap's Avatar
let's get the terms straight. The vent IS NOT the fill plug. The fill plug is 1/3 of the way down on the rear of the case towards the right side. It has a square indentation to use a socket breaker bar to loosen. You have to look hard to see it as it is behind a member.
Old Dec 7, 2009 | 12:58 PM
ricasso's Avatar
just out of curiousity, what fluid/oil do you use? ie it the same as the gearbox.
aholbro1
Dec 29, 2024 06:46 PM
bamforp
Aug 14, 2024 05:36 PM
Jpav27
US Northeast
Dec 17, 2021 05:40 AM
ZJag
26
Sep 5, 2016 03:33 PM
Scarecrow
Mar 28, 2016 03:17 AM
