Differential Rebuild Thread
Old Feb 27, 2012 | 06:47 AM
  #61
avos's Avatar
Think I have good news!
Have just had a good phone call, and I have been informed that if you just want to change the gear ratio, he will charge about 300 Euros for the job.
If it is getting more complicated, like adjusting the gear strategies, it is becoming more time consuming and costly, and it will then cost about 500 euros.
Needless to say that my spare TCM is already in the post ;-).
Old Feb 27, 2012 | 05:08 PM
  #62
adam699's Avatar
Wow. That is some really good news How do I get on this bandwagon?
Old Feb 27, 2012 | 08:06 PM
  #63
adam699's Avatar
As promissed here's the hex dump from the eeprom. After doing more research looks like there is also data in the Flash memory chip which is a bit bigger and harder to read.
File Type: zip
JAGUAR 98 EGS51 93C56.zip (339 Bytes, 136 views)
Old Feb 27, 2012 | 10:12 PM
  #64
avos's Avatar
@SeanB
Let’s wait and see how it works out, although I have good hopes as he does it not just for the Mercedes cars but also Porsches. I have asked for a mild change in Normal Mode so you still can enjoy the GT qualities of your car, and a more aggressive one in sport mode.I hope to have it back next week for the first tests, he was also willing to adjust the strategies again once I have driven it. I have left the points at where the gearbox shifts now, but that is also adjustable.
@Adam699,
Interesting, I hope you find what need and also someone that has changed his ratio.
Old Feb 27, 2012 | 10:26 PM
  #65
adam699's Avatar
@SeanB
@Adam699,
Well, the quotes that you posted sound reasonable so if you would be willing to help me get it done through you or your contact directly I'd be very interested and grateful if it turns out to be doable. I'd also be interested in getting it done on my Porsche as it also has a 722.6 trans with a Siemens TCM.
PS. Ask him to up the torque limiters so the TCM doesn't signal the ECU to pull that much timing between shifts.
Old Feb 28, 2012 | 12:41 AM
  #66
avos's Avatar
Limiting Torque reduction requests are on the menu of course ;-)
Wouldn't stop yet your try (eventhough i think it will be a tough one, as i wouldn't be surprised if some code is scrambled) let's first see if my tcm can be adjusted.
I'll keep you all updated, and am very exited after searching for so many years it may finally be possible at reasonable prices.
Old Feb 28, 2012 | 02:42 PM
  #67
adam699's Avatar
Originally Posted by Brutal
JUST CAUSE ITS A FORD VCM DOESNT MEEN IT WILL/WILLNOT WORK. iTS THE SOFTWARE THAT DETERMINS COMPATIBILTY.
PINION PRELOAD 25-35NM WORK WELL ON MOST ALL DIFFS. IF YOU TAKE OUT THE OLD/NEW BEARINGS AND RACES YOU CAN MACHINE THEM DOWN TO BECOME "SETUP" BEARINGS FOR PRELOAD. BUT I CAN ALSO TELL YOU THAT IN ALMOST EVERY CASE YOU CAN SETUP WITH THE PREVIOUS FACTORY SHOMS AND YOULL BE RIGHT ON. IMO THAT ITS THE CASE THAT DETERMINES MORE THE SETUP THAN THE NEW GEARS. ALSO TO IDENTIFY A POWER LOCK DIFF YOU LOOK FOR THE COLORED BAR TAG WITH BLACK X'S ON IT. THATS A POWERLOCKER. THE COLORED BARS REFER TO THE GEAR RATIO INSIDE.
nOW IDE LIKE MORE INFO ON FOR SURE ABOUT TCM REFLASH BECAUSE I DONT REMEMBER THIS APP. IDE LIKE TO PUT A SET OF 4.09'S IN MINE AND SWAP IN THE NEW POWER LOCKER I HAVE OUT OF THIS OTHER DIFF SITTING ON THE FLOOR SINCE NO ONE SEEMS TO WANT TO BUY IT
Can you give us more info on how to tell the ratios from the colored bars?
Old Feb 28, 2012 | 03:30 PM
  #68
adam699's Avatar
Well, according to the Jag dealership parts dept a Red and Yellow Stripe with a Cross is a locking 3.58 diff. The parts guy said that it's the only color combo he ever seen that actually told him the ratio, so hopefully Brutal will chime in on what the other one's are.
With that said,
Gentleman there is no turning back now. The HU15 Power-Lok with 3.58's is on the way being shipped from a salvage yard.
@Avos I hope your TCM tune works out as now it's a sure thing that I will need it. So far it sounds like the best deal I found. I posted the EEPROM to see if anyone wants to have a stab at it but I'm in no way inclined to try to figure it out myself.
Old Feb 28, 2012 | 04:49 PM
  #69
Sean B's Avatar
I'm grinning here! you guys are 'on a mission' - come on!
@ Adam, did you find out what the 3.58 came out of?
Old Feb 29, 2012 | 07:02 AM
  #70
Sean B's Avatar
Wink
Don't need Brutal -
Differential
blue
blue/black cross
brown
brown/black cross
orange/black cross
red/yellow stripe
red/yellow stripe/black cross
new
Powr-Lok-3.58:1 PART NUMBER JLM11876 (X300)
This info is directly off the JDHT site JDHT
Old Feb 29, 2012 | 11:04 AM
  #71
adam699's Avatar
Originally Posted by Sean B
Don't need Brutal -
Differential
blue
blue/black cross
brown
brown/black cross
orange/black cross
red/yellow stripe
new
Yeah, but what are the ratios assosiated with the stripes was my question
Old Feb 29, 2012 | 11:35 AM
  #72
avos's Avatar
blue 4.09:1
blue/black cross Powr-Lok-4.09:1
brown 3.77:1
brown/black cross Powr-Lok-3.77:1
orange/black cross Power-lok 3.27:1
red/yellow stripe 3.58:1
red/yellow stripe/black cross Powr-Lok-3.58:1
This is from the jdhc link given earlier.
Update on TCM tune:
Unit has been received by my tuner, data read, analyzed, modifying starts tomorrow, so that will be the day I hope to hear it will work!
Old Feb 29, 2012 | 11:59 AM
  #73
adam699's Avatar
blue 4.09:1
brown 3.77:1
Update on TCM tune:
AVOS you are The Man. Always one step ahead of us.
...and I was thinking I'm getting an aggressive ratio with the 3.58. (comparing to the 3.06) I guess the torque from the SC will make up for it. With gas prices hitting $5 maybe 3.58 won't be too bad on the mileage. Does your guy do ECM tuning too?
Old Feb 29, 2012 | 12:16 PM
  #74
avos's Avatar
Can’t wait to call tomorrow, I hope so much that this time it will workout, it will be a huge step forwards. But even if it has worked, I still need to test it in my car, but then it should just be fine tuning.
I was actually thinking to go to a 2.86 or so, as I have power in abundance, and such a ratio would give better fuel consumption as I drive just too much. I may consider it again if the tcm tune will work out. It would also allow a top speed of about 200 mph with the larger tires I have, but admit that I wouldn’t try that on the open road...
For tuning the ECU I work with someone else, he is looking now to disable to speed limiter.
Old Feb 29, 2012 | 05:34 PM
  #75
JgaXkr's Avatar
I run a 3.77 rear axle ratio & love the acceleration. I recomend it to anyone who is looking for more acceleration. I think a 4.09 might be to much, but would love to find out.
Old Feb 29, 2012 | 08:16 PM
  #76
Brutal's Avatar
a high 3 ratrio 3.70-3.90 is a great street performance gear with overdrive and a 28" tall tire. A 4.10 is really stout and you would litterally be surprised and surpise alot of others on the biggest contest of speed(stop light takeoffs) would be alittle much for everyday highway driver. But for performance and not everyday(or someone not minding the little more fuel used) the 4.10 range would be awesome. I just put 4.56 gears in the front and rear diffs of my Nissan Frontier from 3.36. I wish I had done soooo much sooner, but gears werent avail to do it till recently. I run a 32" tire and there are many great gear ratio calculators online to tell you the rpm, speed tire size etc and change can be made with the click of a mouse.
heres 1 I like to play with gear ratio calculator
Old Mar 1, 2012 | 10:46 AM
  #77
avos's Avatar
The TCM is going to be written (that already works!) with a new base setup, and also with some adjustments as requested, it all should workout. Then it will be shipped back to me, where I will do some test driving. We probably have to make some small adjustments afterwards, so we get a good base package for others to use also (although you can always have something changed if you have specific requirements).
Changing gear ratios is no problem at all, that can be either with the stock tune or with the one we are making now. Now I need to wait a couple of days before I have it in my car, can’t wait to see if it all worksout.
Old Mar 2, 2012 | 01:22 AM
  #78
plums's Avatar
Well, it's officially "tomorrow" now
Old Mar 2, 2012 | 05:19 AM
  #79
avos's Avatar
Wel, for me today is the day after tomorrow, yesterday was tomorrow, or are you saying I was a day to early ? ;-)
Old Mar 2, 2012 | 10:53 AM
  #80
adam699's Avatar
A bit of a setback.
I get the freight today and this is obviously not a locking diff:
Not a locking diff x300 - YouTube
Back to searching
