Dirt between the pleats in the air flter
Old Oct 7, 2017 | 01:40 PM
Steve W's Avatar
Default Dirt between the pleats in the air flter
I changed my XJR's AC Delco air filter after only 10K miles and was surprised how much dirt was between the pleats when I bent the filter. It runs fine so hopefully this is a good sign that the dirt isn't getting into the engine. Is this common? I don't remember previous cars' filters looking that dirty.
Old Oct 7, 2017 | 02:14 PM
Daim's Avatar
Exactly the purpose of the filter. Depending on where you live, it can be more or less.
Now, consider that you get a free flowong filter from say K&N. The ***** you found today would not be there, bdcause it would be in the engine. Same goes for sand. I live in a very dusty area, even though wet. When dry, the ground is easily turned to a dusty sandy air. My air filter box is always FULL of sand when I change the filter. My brother's Passat with a K&N filter is always spotless inside... Even though he lives in the exact same area and drives as much as I do.
People believe the K&N crud will increase flow without sacrificing air cleaning... I call out BS. Air flow is increase by dropping filtration. That is the only way it works.
But back to your filter... It did the job just right then!
Old Jun 25, 2020 | 01:24 PM
worrasf's Avatar
Deleted - wrong thread
mcm97
Jan 18, 2023 08:14 PM
Gerard Radimaker
May 15, 2016 01:41 PM
amcdonal86
Oct 5, 2012 06:33 AM
