Disintegrated door handle gaskets
Old Jun 17, 2014 | 09:30 AM
poisonpill's Avatar
Default Disintegrated door handle gaskets
Has anybody found a good solution for these XJ's disintegrating door handle gaskets? I don't really care that the rubber is falling apart, but whenever it rains something in the rubber combines with the water and causes unsightly white streaks down the door. It seems to require buffing to remove too.
Does anybody know of maybe some rubber adhesive or tape to tape around the handle? Thanks.
Old Jun 17, 2014 | 09:47 AM
WhiteXKR's Avatar
See Welsh Enterprises, Inc - Jaguar XJ8 (98-03) Body Fittings Front Doors Parts
Old Jun 18, 2014 | 12:02 AM
Zues's Avatar
YES!!! I was waiting to do a right up on this but. . . The tape is a rubberized 1/8" thick solution that can be stretched around corners. It can be found at Home Depot, most likely on an end cap. If you ask about it you will most likely get the famous blank stare of HD customer service so you will have to do some searching. Cut it into strips about 6-8mm wide I used an electric scissor. Makes it look like it was one clean cut. Also clean the surface you are sticking it to.
Attached Thumbnails Disintegrated door handle gaskets-20140118_203527.jpg   Disintegrated door handle gaskets-20140120_175001.jpg   Disintegrated door handle gaskets-20140118_214108.jpg
Old Jun 18, 2014 | 01:57 PM
poisonpill's Avatar
Moisture sealing electrical tape eh? Will have a look.
What's involved to remove the handle? Does the door have to taken apart? Thanks.
Old Jun 18, 2014 | 11:12 PM
Zues's Avatar
Door cards obviously, drivers door has a guard and plastic clip that can be tough.
Old Jun 28, 2014 | 01:53 PM
Lear45's Avatar
I recently repainted the car and the body shop suggested replacing the handle gaskets.
I got them from Welsh Enterprises and they look and fit great. Just like the originals were 16 years ago. They are sold in pairs. Front and rear are the same set. It is a rather complicated seal. Not just a flat piece of rubber. Worth the money. Replace the door handle cable while it is all apart and save yourself double work. Welsh enterprises sells that part as well.
Dz1rfj
Jul 17, 2018 10:29 AM
Dz1rfj
Sep 16, 2015 03:44 PM
sadepol01
Sep 11, 2015 05:26 AM
1964Daimler
Sep 9, 2015 11:28 AM
hoodun
Sep 7, 2015 07:02 PM
