DIY transmission swap
Old Mar 20, 2021 | 01:01 PM
Highhorse's Avatar
Well, at least you got it in, now that rascal of a code. If your using the same shift indicator, that may be your problem (as you suspect)...https://www.carobdcode.com/p0705-jag...it-malfunction
Its really not worth anything unless you rebuild it, as you know, a straight used swap is $500, but a rebuild is minimum $2500, around $250 for the kit. Don't know if that's worth your time? You could go by a Merc and/or Jag Inde' and see if he's interested in it.
If you want to review how to break it down or find what might be the issue, Gary Ferraro is very knowledgeable... https://www.youtube.com/c/GaryFerrar...ch?query=722.6
John Nevets
Nov 21, 2020 03:48 AM
bluejaag
Sep 26, 2019 09:05 PM
mrplow58
Apr 30, 2015 09:26 AM
Rev
Aug 5, 2012 09:54 AM
racerboydrew
Nov 17, 2008 07:08 AM
