Do lower front shock bushings need to be pressed?
Old May 1, 2012 | 05:22 PM
SirJag's Avatar
Default Do lower front shock bushings need to be pressed?
2001 VDP. I know the uppers don't, but how about the lowers?
Thank you!
SirJag
Old May 2, 2012 | 05:01 AM
Sean B's Avatar
nut, bolt and washers to pull it in in situe is a fast workaround.....
Old May 2, 2012 | 07:46 PM
SirJag's Avatar
Hi Sean:
Thanks for your reply.
So, then, without a press... how long a job would you say a pro mechanic could install both the top and lower shock bushings?
And have you replaced them yourself?
Thanks very much,
SirJag
Old Jul 2, 2012 | 10:38 PM
Orlando Holwerda's Avatar
Hello everyone, I have a 1996 Jaguar vanden plas. I started a project today to remove the lower shock bushings.
The old lower shock bushings seem to be seized onto the housing. I tried to pound it out with a hammer and and small pipe, but it has not moved one bit.
The outer ring of the bushing is made of some type of metal, but it does not come out. It seems to be stuck in there. What can I do to get the outer ring of the old bushing out of the lower shock housing?
Neil1664
Jan 20, 2022 08:59 PM
KarimPA
Sep 12, 2015 08:15 AM
EZDriver
Sep 8, 2015 09:25 AM
tberg
Sep 7, 2015 07:32 AM
Tar
Sep 6, 2015 11:24 AM
