Does the 01' Jaguar XJR also suffer from the tensioner problem?
Old Oct 13, 2008 | 08:44 PM
Brutal's Avatar
Default RE: Does the 01' Jaguar XJR also suffer from the tensioner problem?
I dont remember when Jag started useing the updated tensioners on production, but if they dont have records showing you dont know without pulling a cam cover and looking. And thats a great price if its well maintained, otherwise it could be adjusted by them to pay for needed repairs that you dont know about.
Old Oct 13, 2008 | 09:11 PM
dougs02's Avatar
I bought an '02 XJ8 back in Nov. with 20,500 miles on it and the late previous owner had the tensioners replaced under warranty. Maybe you can get someone to run the history of the VIN number for past dealer work.
Doug
Old Oct 13, 2008 | 09:44 PM
Brutal's Avatar
the only thing you couls get are bulletins, rcalls and warraty repairs, you have to go to servicing dealer for records of customer pay work or extended warranty work
Old Oct 14, 2008 | 06:13 AM
JagtechOhio's Avatar
David,
Price sounds good. Tensioner revision was introduced at engine number 01 08 13 0000. This number is a date code, and does not correlate directly with VIN number or vehicle build date. On an 01 car, you have to read it from the vertical rib on the left side of the cylinder block.
It's a fair bet that the '01 you are looking at has an engine preceding the magic number, so you only have third generation tensioners if they have been changed since '02.Add my voteto pulling a cam cover and seeing what is fitted.
jdzubas
Oct 4, 2015 09:14 AM
Fraser Mitchell
Oct 1, 2015 04:06 AM
martybmw
Aug 31, 2015 08:41 AM
BlacXJRcat
Aug 28, 2015 07:10 AM
Zues
Aug 27, 2015 12:02 AM
