Does Harmon Kardon audio have a subwoofer
Old Feb 1, 2015 | 08:27 PM
dcdecs's Avatar
Default Does Harmon Kardon audio have a subwoofer
I have a 99 XJR with the Harmon Kardon sound system. Does this audio system have a subwoofer in the shelf behind the rear seats? A previous owner has removed it and messed with the wiring and I'm trying to put it all back together.
Old Feb 1, 2015 | 09:36 PM
Mark SF's Avatar
Yes it does, in the back shelf.
Old Feb 1, 2015 | 09:39 PM
Gippsland's Avatar
Short answer is yes.
Longer answer is if it was ordered as a premium sound system from Jag. Otherwise no. Not an easy retro going by previous posts. Removing the parcel shelf is a pain in itself.
PS. Wish I had one!
Old Feb 1, 2015 | 09:43 PM
Mark SF's Avatar
Oh boy, yes, it is indeed a pain!
Old Feb 2, 2015 | 03:37 AM
grandell's Avatar
Should be easy to replace if the wiring is still there. The catch is that the 6x9 "subwoofer" is a dual voice coil unit. I can't remember off the top of my head if it's dual 2 ohm or 4 ohm, but google will know (and most likely link you to threads on here... I'm just too lazy to do it myself, sorry).
I'm not aware of any aftermarket 6x9s that will fit straight in and maintain the dual voice coil setup. You don't want a single voice coil speaker, they just don't work that way. The reason for the dual voice coil setup is that the amp runs two sub channels, one for the left and one for the right, and then sends both signals to the sub.
If you have a car stereo outlet near you that deals in medium to high end gear they might be able to find you something. I wouldn't waste my time at the lower end shops though.
Presence
Mar 13, 2016 02:21 PM
King Charles
Oct 16, 2015 01:25 AM
Rocky15
Sep 28, 2015 04:59 PM
42Ajd
Sep 26, 2015 07:04 PM
