door check frustration
Old Sep 5, 2017 | 04:44 PM
smith356's Avatar
Default door check frustration
bought a door check off ebay. Today I removed the old one, and while test fitting, discovered the new arm is not in the extended position and won't reach the connector on the pillar. I've tried and tried to get it to extend - no luck.
Help, please !
Old Sep 6, 2017 | 05:09 PM
smith356's Avatar
was able to get it extended via vise and brass hammer !
Old Sep 6, 2017 | 08:15 PM
motorcarman's Avatar
A vise and a BFH always does SOMETHING!!!!!!!!!! (even if it's wrong)
That is what I would have done.
bob
Old Sep 7, 2017 | 08:28 AM
smith356's Avatar
bob
Thanks, Bob... good to know I'm not alone !
Old Sep 7, 2017 | 10:20 PM
pdupler's Avatar
I don't know about the hammer, but I'd try putting it in a vise (in a way that doesn't pinch it off of course), then put a screwdriver through the arm and PULL. Maybe use a lever against the screwdriver and vise if necessary. But leave the hammer for fitting General Motors parts.
Old Sep 8, 2017 | 05:52 PM
smith356's Avatar
Default doorcheck
It turned that I had both a broken door check and damaged metal. A couple of washers perked it right up and now all is well !
