Door handle link replacement c/w pics...FAQ
Old Feb 26, 2015 | 02:35 AM
erick_151's Avatar
My handle snapped on the outside of my driver's door and on my rear driver's side door the handle just flops with no play as if it's not engaging anything.
Again, both are the exterior handles.
Any advice would be greatly appreciated!
Also, for gaskets I found a cheaper price: http://www.ebay.com/itm/281554655486
Old Feb 27, 2015 | 10:37 AM
edwood's Avatar
Does anyone know if the cable from a xj8-rear door will fit on vdp front drivers door. Thanks Ed
Old Mar 30, 2015 | 02:01 AM
erick_151's Avatar
So I dove in and replaced my exterior door handle on the front left driver's side today (writeup and pictures pending), but I encountered a major issue.
After I put everything back together, my driver's window won't roll down. I hear the electronic click and all other windows go down, but not the driver's one. Won't go down via exterior turn key or center console button either.
Any advice is appreciated!
Old Mar 30, 2015 | 07:22 PM
Lear45's Avatar
Door cable $35 with free shipping
Jaguar XJ8 1998 2003 Front Door Handle Repair Cable | eBay
Welsh Enterprises has cable and door handle gaskets.
Old Mar 31, 2015 | 12:25 AM
erick_151's Avatar
Thumbs up Solved
Pulled fuse #15 from driver's side(left) rear passenger floor board fuse box and reinserted. Problem solved.
Will provide write up and picture for exterior handle job probably this Saturday.
Cheers!
Old Feb 18, 2017 | 07:54 PM
montypeek's Avatar
Excellent summary! Had trouble trying to find a solution to my problem which is exactly the same. I truly appreciate all of your detail- explanations and pics. I realize it was very time-consuming posting such detailed information.
I have one question- I purchased the replacement cable only (no handle assembly). Is it possible to simply replace the cable without having to remove the internal door hardware (I.E. internal brackets)?
Old Nov 7, 2017 | 04:33 PM
King Charles's Avatar
Mine just gave up the proverbial ghost lol about to tackle this now.
Old Nov 10, 2017 | 09:02 PM
  #28
Funny thing is my inside handle stayed extended on exiting. Then I lightly forced it back in w/ my hand. It's back working, just slow to retract back. I think I will pull the door card & see if the little collar on the cable has just become misaligned as opposed to breaking & falling off.
Either way the part's ordered & shall be replaced. It's been flirting w/ failure for almost a year now lol.
Old Nov 13, 2017 | 04:56 PM
Jhartz's Avatar
Maybe a little WD40 is all you need.
Old Nov 29, 2017 | 05:25 PM
  #30
Ok my cable finally arrived, time to motivate lol.
Old Dec 13, 2017 | 12:23 PM
  #31
yeldogt's Avatar
Thanks everybody -- will order just the cable. And the link to the procedure is great -- don't know how I missed .... thanks KC
Old Jul 9, 2018 | 05:27 PM
  #32
Nicdilla's Avatar
What a crappy design. The cable and the weak cast L-shaped mechanisms. I am sure that is the best they could manage I guess. I hope they improved with the latest tech available to help design important mechanisms like "THE DOORS"! God forbid you have to get out of the car in a hurry, and then 'snap', there goes the cable, or there goes that plastic crap they made the inside one on, or the cast metal L-Shaped lever design on the exterior. Has anyone ever heard of CFD at Jaguar?
Old Jul 10, 2018 | 04:20 AM
  #33
xjay8's Avatar
What a load of tripe!! There is nothing wrong with the design, it's universally used.
The BIG problem is the abuse handed out by meat fisted oiks who think the bloody door handle is an axe handle and wrench the crap out of them and lack of regular lubrication....it's called mechanical abuse!
The same as doors are thrown open against their check straps and slammed shut with full force.
The same applies to the bonnet/hood cables because of poor adjustment and lack of lubrication.
Old Jul 11, 2018 | 02:16 PM
  #34
Z07Brandon's Avatar
I have been putting this off for to long. Thanks!
Old Jul 13, 2018 | 12:56 PM
  #35
L.cd's Avatar
Originally Posted by mzs_biteme
So my door handle link snapped... For over a week I had to roll down the driver side windows to let myself out... Talk about embarrassing....
So I ordered a new link/door handle assembly from eBay for $80...
I also went to Harbor Freight Tools to get this:
Attachment 166774
Very handy for removing trim.
Here is what I did (pic):
RED arrows first:
- remove the screw in the door handle cup, and remove the cup by pulling on the door handle and working the cup out.
- remove the screw under the arm rest
GREEN arrows:
- use a nylon pry bar to pop out the two fasteners holding the faux-wood trim, and then SLIDE is to the LEFT. Don't try to pull towards you or it will snap.
PURPLE circles:
- use the pry bar again on the pin fasteners.
Attachment 166775
This is why you wanna slide the faux-wood insert and not pull it:
Attachment 166776
Anyways, To remove the door trim itself, first PULL the bottom part out to where you can see all the side and bottom fasteners out, and the trim itself is about 2" from the door, then LIFT the trim UP.
Here is what you'll see:
Attachment 166777
Disconnect the speaker wire, and the yellow connector for the door/windows switches. You can leave the door light wire on as it's long enough for you to put the trim on the floor without the need for disconnecting it.
The door lock assembly and the links.
Attachment 166778
Attachment 166779
Was able to squeeze my camera in the door frame pointing towards the lever that the link connects to:
Attachment 166780
Getting ready for this project I had problems finding good (any) pics that would help me visualize what I was about to get myself into. Hopefully this will help others that may run into this issue...
Mike
Hey Mike thank you for the explanation, you are awesome!!! Can you please provide a link and price that you bought the new “metal” wire?( i think you understand what i mean)
Thank you.
Old Jul 23, 2018 | 11:51 AM
  #36
2manycats's Avatar
Nice write up with pics. Great help!
I'm working on X300 '97 VDP and it looks the same - at least the cable does. What seems to be missing is a reference to a small retaining clip. It's part #3 in the diagram https://tinyurl.com/yaapwvgn
Can anyone shed light on how this fits?
Thanks!
Old Aug 6, 2020 | 11:39 AM
  #37
ZOLTEN2005's Avatar
Default Thank You SO much!
Mike,
Your instructions are extraordinary! I just bought a 1998 XJR and I had the same problem with my door as you had. Yes, it's extremely embarrassing!
Just so you know... I am a 50 year old woman with no experience in working on door panels. I was able to get the panel off with no problems and get the cable out with ease due to your post.
I am writing this just to say, "Thank You." Without these pictures and instructions, I would've had to take her to a shop who wanted to charge me $200 JUST to open her up! I sure appreciate it.
Many Blessings To You. You Rock!!
Old Jan 2, 2021 | 10:12 AM
  #38
Alan Wrench's Avatar
Default X308 door handle cable replacement
Based on prior posts on this forum and information from elsewhere steps involved in performing this repair are listed. Please post if I missed something, got something wrong, etc.
1. Disconnect the negative battery lead
2. Remove the small round cap from the middle of the handle cup
3. Remove the “first” screw located beneath the small round cap
4. Remove the handle cup
5. Remove the wood veneer
6. Remove the “second” screw from beneath the arm rest
7. Loosen the door panel clips
8. Remove the door panel
9. Disconnect the electrical connections (speaker, switches, and light)
10. Remove the Styrofoam plastic layer
11. Remove the old cable
12. Install the new cable
13. Re-install the Styrofoam plastic layer
14. Re-connect the electrical connections
15. Replace, in order: the door panel, the “second” screw, the wood veneer, the handle cup, the “first” screw, and the small round cap, and
16. Re-connect the negative battery lead.
Also, a couple of questions: 1. Is it recommended to lube the inner cable before installation? And 2. Have others encountered/replaced what has been referred to as “a small spring clip on the catch that is used to retain the cable outer into the latch assembly”?
Old Jan 3, 2021 | 07:24 AM
  #39
eliotb's Avatar
Well, I’m new to this thread ... but the process doesn’t seem to have changed a bit from when I was stripping down the doors in my ‘89 XJ40 to replace door handles. The more things change the more they stay the same. I will say the pictures were most helpful.
Old Jan 18, 2021 | 03:13 PM
  #40
Amphicar770's Avatar
Thanks for the excellent write up. Replaced my cable yesterday, quick and easy fix.
I also updated the front speakers while I had door panel off. Alpine 2-ways fit perfectly.
My ebay cable did not have the foam sleeve which presumably keeps it from rattling against door. Removed old sleeve (slice with razor) and glued it on new cable.
Thanks again!
